SolaraGuy.com • View topic - Rack And Pinion noise
Postby adam2562 » Thu Dec 19, 2002 8:23 am
:roll: ever since i had my car lowered my car makes an awful grindigng noise whern i tuen the steering wheel... wut the heck is that.. it sounds sooo bad, i checked power steering fluid and its all there... help please
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby MonkieX » Thu Dec 19, 2002 1:50 pm
probably rubbing from your tires on your fenders.
MonkieX
Postby adam2562 » Thu Dec 19, 2002 10:38 pm
no, it sounds like metal to metal noise.... one guy at my dealership(toyota) said that loweringit may have put stress on the suspension...??
adam2562
Postby NaptownSolara » Fri Dec 20, 2002 7:22 am
Adam, I don't see a strut upgrade in your sig. If you just put in lowering springs, and didn't upgrade your struts too, then your mechanic is right, you are putting undue stress on your stock struts.
2001 Toyota Solara SLE V6 - Silver
Alpine/Kicker audio system
NaptownSolara
Postby adam2562 » Fri Dec 20, 2002 7:41 am
ok i'll try getting up some money to get thos done, wut brand do you recommend? TRD r way too expensive
adam2562
Postby NASTY » Fri Dec 20, 2002 7:49 am
go for the tokicos, everyone seems to be happy with those
'01 SLE V6
NASTY
strut
Postby .,zXC » Sat Dec 21, 2002 3:44 pm
i had that problem gridding is because the top of the strut was not lined up correctly and the bearing is cracked so if u take it apart the strut apart u might find the bearing is broken
.,zXC
Postby Flipside909 » Sun Dec 22, 2002 3:21 am
Tokico all the way.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
