SolaraGuy.com • View topic - Dyno Tuning in So. Cal
Postby indiglosolara » Tue Aug 23, 2005 11:37 pm
Hey guys,
I was wondering if anyone knew a good place to bring my car to get dyno tuned..
I'm currently running the Injen SR Intake with greddy cat-back exhaust with the resonator and piping modified. I just want to make sure that my car is running correct with this set-up and other misc parts i have installed. This way i know that im not running to lean or to rich.
Any help would be great.
Thanks
Kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby ~Spadwaller~ » Tue Aug 23, 2005 11:46 pm
California Motor Sports "CMS" (formerly Harv's Performance Ctr)
(562) 907-7834
12221 Rivera Rd
Whittier, CA 90606
Ask for Scottie or James they are the motor geniuses they fixed up my S/C install when that other guy ****ed it up, Marvin is the owner. These guys do "everything" with performance Dyno, S/C, turbos, anything performance from Hondas to Ferrari's
They open early and close late and they now have experience with Solara's, I found out about them on SuperStreet Magazine online
~Spadwaller~
Postby krawzyazn » Wed Aug 24, 2005 12:37 am
WACK call JPP they will shoot you to the right direction SPLIT SECOND :lol: they have experiance with the 2az-fe mine and richards :lol: :drinking: :drinking: :drinking:
Postby Turbosolara » Wed Aug 24, 2005 12:46 am
it is depend on what device you want to get tuned. just make sure they have nomerous experience about the tunning. But i dont think you need tunning becasue what you had done is minor mode, the gain you see wont be that much. it is kind of waste money (piggy back + tunning) ususally tunning start at $150 set up fee, and $100-$200 per additional hours. I spend $450 tunning at autolink and it was not that great, but i think because i was there at bad time...which is the tunner's lunch hour and his date was waiting for him.
Postby Jackass-Jeff » Wed Aug 24, 2005 7:48 am
kenny, after adding all the mods, reset the ecu and have it correct for the add-ons. After that, go dyno tune it.
VVT-i engines are a bitch if you forget to reset the ecu
1GR-FE ftw!
Jackass-Jeff
Postby indiglosolara » Wed Aug 24, 2005 9:14 am
Jackass-Jeff wrote:kenny, after adding all the mods, reset the ecu and have it correct for the add-ons. After that, go dyno tune it.
well after each mod i've reset the ECU. However i have a feeling im running too lean with the Injen Intake. So thats why i wanna get my car dyno tuned to comfirm my own results.
I think ill call JPP and see what they can do for me. Also i might look into the headers by JPP while im at it.
Thanks..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Jackass-Jeff » Wed Aug 24, 2005 12:19 pm
injen SRT + exhaust will run lean on the 2AZ regardless of ecu resetting. The JPP will even it out slightly but you may need to:
get rid of the injen for a KN
-or-
get the a/f controller from the place jpp sends you to dyno
1GR-FE ftw!
Jackass-Jeff
Postby indiglosolara » Wed Aug 24, 2005 1:49 pm
Jackass-Jeff wrote:injen SRT + exhaust will run lean on the 2AZ regardless of ecu resetting. The JPP will even it out slightly but you may need to:
-or-
Whats the Damage of running too lean with the injen and exhaust in long term factors???
im just trying to determine wheather i should take the injen off and run the stock air box with k&n filter or even the TRD filter.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Jackass-Jeff » Wed Aug 24, 2005 2:57 pm
low fuel amounts will cause the engine to run hotter and may cause the piston rings to burn, and then you will get 'blow-by' or burnt rings/head/pistons/etc
Call me for more info. I'll be back from lunch at 415PM PST
652 3376
1GR-FE ftw!
Jackass-Jeff
