SolaraGuy.com • View topic - Cleaning MAF safely
Cleaning MAF safely
Cleaning MAF safely
Postby SC V6 » Sun Sep 04, 2005 9:24 am
Anyone know the correct procedure to clean the mass air flow sensor w\o making it read incorrectly?
thanks
SC V6
Postby Astro » Sun Sep 04, 2005 11:58 am
I've just been spraying inside w/o opeining the flap so you don't mess with the sensor. Then, using a toothbrush to brush it off. After that I would carefully clean up with a clean rag. I've done this quite a few times now, w/o any problems. It's possible you've already damaged the sensor.
I was just watching that show 2 guys garage (another repeat), but they said to be very careful spraying cleaner inside because the cleaner can/will damage the sensor.
Postby JoeB » Sun Sep 04, 2005 12:03 pm
Scott, the recommended procedure is to not clean the MAF because of damage to the sensor wire. Personally, I ignore that advice and haven't had trouble.
One way to clean it is with the long Q-Tips and some of the pure alcahol, 97% or higher. The regular rubbing alcahol is not good, it is like 70% pure and the rest is skin softner that protects skin but is not good on electronic components. Then you very gently roll (not rub) the alcahol soaked Q-Tip over the 2 wires inside the MAF.
The other way is with a spray. If you have an electronics supply store near you, pick up a can of electronics spray cleaner that is safe for ABS plastic and has NO lubricants! Simply spray those 2 wires. With either way, make sure they are dry before you try to start the car. Either method will dry quickly since those chemicals evaporate quickly.
As always, this is a try at your own risk. Our stock MAF costs about $180. If you pull your MAF off and it is very dirty and dull, it's up to you to decide if you want to risk doing this. The way I look at it is, if you damage it, so what if you were going to have to buy a new one any way. I haven't damaged 1 yet. -JoeB
JoeB
Postby JoeB » Sun Sep 04, 2005 12:04 pm
Astro wrote:I've just been spraying inside w/o opeining the flap so you don't mess with the sensor. Then, using a toothbrush to brush it off. After that I would carefully clean up with a clean rag. I've done this quite a few times now, w/o any problems. It's possible you've already damaged the sensor.
It sounds like you are talking about the throttle body rather than the MAF. -JoeB
JoeB
Postby Astro » Sun Sep 04, 2005 12:09 pm
ooops, didn't read the post correctly.... :lol:
Postby SC V6 » Sun Sep 04, 2005 12:35 pm
yeah.. I was thinking the same thing about Astro's post..
The Maf that I was going to clean was the supra one that I ordered.. just want it to be super clean before I install it
SC V6
Postby Hefty » Tue Sep 13, 2005 2:52 pm
i've usually just used spray can of electronic parts cleaner. Never had a problem finding it at a local parts store. The stream of cleaner comes out with a enough force to blow it clean.
1999 Solara SE V6
2003 Nissan 350Z Track
Hefty
Postby XLr8 » Tue Sep 13, 2005 4:42 pm
XLr8
