SolaraGuy.com • View topic - Question about ABS Light
Postby HTown-Solara » Tue Sep 06, 2005 2:24 pm
The ABS sensor on my car in the rear wheel is broken. Happened when I was changing the strut. Is there any way I can make the light for ABS and TRAC not flash without fixing the sensor? If anyone knows it would be a big help! Thanks
HTown-Solara
Postby Jon11582 » Tue Sep 06, 2005 2:26 pm
Take the bulb out of the dash. Only 4 screws, and no other tools required. But...you should probably get it replaced for safety's sake.
2000 Black Solara SE
Jon11582
Postby SleeperSolara » Tue Sep 06, 2005 5:34 pm
Yeah you should get the ABS senser for saftey sake.
My ABS light is on also something is wrong wit hte rear left wheel actuator.
Brakes fell better.
But the ABS light gets annoyin' while it stays lit.
