SolaraGuy.com • View topic - fuse goin out
fuse goin out
fuse goin out
Postby greeensolara » Fri Sep 09, 2005 4:51 pm
out of no where while driving and using my signal light, it just stopped workin ... so i pulled over and checked the fuses.. i found both, the one under the steering wheel and the one under the hood, burnt! i have no clue what the problem is... and when i changed them they would burn when i use the signal or emergency light... i have no clue whats goin on... nothin was added electrically... if anyone has a tip .. please inform me with the possibilities... id really appreciate it! thanks in advance
-Moe
greeensolara
Postby SleeperSolara » Fri Sep 09, 2005 8:02 pm
You have the right fuses in.
Postby Hsakuragi » Fri Sep 09, 2005 8:04 pm
did u change ur singal bulbs to led?
Hsakuragi
Postby greeensolara » Sat Sep 10, 2005 1:06 am
no i havent changed my bulbs to led... and they are the right fuses... none of the bulbs are out either... im so confused
any other help?????????
greeensolara
Postby Turbosolara » Sat Sep 10, 2005 1:36 am
you had crossed wires somewhere. have your car involved in any accident? check the bulb socket and wires for damage.
Postby SleeperSolara » Sat Sep 10, 2005 8:16 pm
Yeah probably you could have a bad ground some where??
Wheneva you use the signal it could be groundin' somewhere to make the fuse blow.
Postby greeensolara » Sat Sep 10, 2005 8:21 pm
i had an accident.. but it was from the side on the back end of the drivers side... the signals were still workin... so i doubt thats the problem.. the car has been fixed and it still has the problem ... what ground wires would affect it.. is it possible my subs and amp have to do with the shortage.... im so confused and dont know what to do...any or some help will do.. i didnt play with any wires.. so no way that i crossed em....
greeensolara
Postby Hefty » Tue Sep 13, 2005 1:16 pm
It is a bad ground somewhere. Could either be a loose battery cable or something to do with your radio equipment. I actually had something similar happen to when I hit the turn signal the radio turned itself off. When turned the turn signal off the radio turned itself back on. Shortly after that happened a couple of time the car started to turn over real slow when trying to start it. I still had the same battery that came with the car so I went to replace it with a new one. I discovered that the battery cables were no where near tight enough on the battery. In fact I could twist them off with my bare hands. Since, I've replaced with the biggest battery I could fit in there and it has been running like a champ and haven't had the weird turn signal issue come back at all.
1999 Solara SE V6
2003 Nissan 350Z Track
Hefty
