SolaraGuy.com • View topic - Abs light......
Abs light......
Abs light......
Postby ICrazyChrisI » Sun Sep 11, 2005 6:43 pm
Did the suspension change from the JIC back to stock, replaced the torn abs sensor with a brand new one..but the lights still on? I left the neg terminal on the battery off for like 5 minutes, but is there any particular way to 'reset' it? Or maybe I have another broken abs sensor?
ICrazyChrisI
Postby Astro » Sun Sep 11, 2005 7:55 pm
So, did you replace the sensor yourself? I've got to replace mine and I don't remember anyone else ever doing it.
You probably have another broken sensor. Would a OBDII scanner show this?
Postby ICrazyChrisI » Sun Sep 11, 2005 7:57 pm
I replaced it myself. I tugged at the other 3, and they're all on tight..so idno what the screw.
ICrazyChrisI
Postby Astro » Sun Sep 11, 2005 8:14 pm
So what did it cost for the sensor?
Postby Mole » Mon Sep 12, 2005 12:57 am
a separate reader is needed for the abs system
