SolaraGuy.com • View topic - Cigarette lighter outlets, part II
Postby SpikedMantis » Mon Sep 12, 2005 3:16 pm
Well, if I didn't keep un-plugging things from the outlets, I wouldn't have this problem. The lower outlet came out when I pulled out the adapter, and now it doesn't work. I think it just became un-plugged from the power source, but I haven't been able to reconnect it. Any suggestions on what I need to do, like taking apart my dash?
SpikedMantis
Postby Jai_Jai_Binks » Mon Sep 12, 2005 3:35 pm
1. pull the ashtray off (completely)
2. pull from bottom of the center cluster bezel...(put outwards, not upwards)
3. When the bezel comes out, check connections at the bottom to see if clip is on the ahstray, if that doesn't solve the problem, it your fuse by your coinholder (well behind the coinholder).
Postby SpikedMantis » Thu Sep 15, 2005 11:09 am
Awesome, thanks for the info. As I expected, it was just disconnected. I just reconnected it and it works now.
SpikedMantis
