SolaraGuy.com • View topic - Cigarette lighter outlets, part III
Postby SpikedMantis » Mon Sep 12, 2005 3:18 pm
Okay, last question, I swear! How much power can I suck from my stock battery using one of these?
https://www.escortradar.com/cp/cgi-bin/cp-app.cgi?&pg=store&sub_pg=prod&ref=50
Would it be feasible to use two of these (1 for each outlet) so I can have 4 outlets without killing my battery?
SpikedMantis
Postby devilsushi » Tue Sep 13, 2005 8:03 am
I had a XM roady, Radar Detector, a Garmin GPS unit and my cell all hooked on both outlets, and as the power is cut when the engine is off there should be no problem leaving them in, but it will leave the area as a clustered console
devilsushi
Postby Mole » Tue Sep 13, 2005 10:08 am
its not the matter of killing your battery, but killing your fuse.
if you pop them, you know you are using too much.
Postby SpikedMantis » Thu Sep 15, 2005 11:11 am
devilsushi wrote:I had a XM roady, Radar Detector, a Garmin GPS unit and my cell all hooked on both outlets, and as the power is cut when the engine is off there should be no problem leaving them in, but it will leave the area as a clustered console
How long have you had that running? I don't mean at one time, but how long have you had that set up on your car. I just want to make sure that it can stand the test of time.
SpikedMantis
Postby Mossy » Thu Sep 15, 2005 1:50 pm
Hardwire things. Make's life easier. Solara's dash and center console make it easy to wire up pretty much anything.
[Silverstars|Nokya Yellow Fogs|Black Clear Corners|Pioneer DEH-P7700MP|Kicker 15" CompVR|Hifonics Amp|Knuconceptz]
Mossy
Postby JAYDEE23 » Sat Sep 17, 2005 7:52 am
i wrote a tutorial on removing center consule w/out breaking the friggin tabs like i did..it is real easy and a great place to hardwire stuff...
JAYDEE23
