SolaraGuy.com • View topic - Why is this happening?
Postby Nyyankees3511 » Fri Sep 16, 2005 12:15 pm
I cleaned by throttle body and put some super gas (used regular before) yesterday and it seems as if my car is not making the gas mileage as before what could be wrong?
Nyyankees3511
Postby Somedude » Fri Sep 16, 2005 12:30 pm
if your car requires regular, only add regular. Adding a higher octane does nothing but gives you bad gas milage.
Somedude
Postby SPF 0 » Fri Sep 16, 2005 12:30 pm
I've had people swear that their mileage improves after an oil change. My guess is that their tires (post change) are now properly inflated.
Has anything else changed since you last checked your mileage?
SPF 0
Postby Nyyankees3511 » Fri Sep 16, 2005 12:38 pm
I didnt change anything except different octane gas, kandn filter and the throttle body cleaning.
Nyyankees3511
Postby SPF 0 » Fri Sep 16, 2005 12:45 pm
How old is the previous mileage reading?
SPF 0
Postby Jon11582 » Fri Sep 16, 2005 12:45 pm
If you got a V6, might be the fact that its actually using that gas to push some more power now, instead of retarding your engine so it can take regular gas. Been gunning it lately?
Thats the only way that higher octane can lead to lower gas mileage - the gas itself is no more or less effiecent.
Since you cleaned the filter and TB, it could be that it can now take in the air to use the extra fuel now, but again, youd have to be revving alot to actually notice a difference in gas mileage.
Just cruising, none of these changes should offer worse gas mileage.
2000 Black Solara SE
Jon11582
Postby StockSolara » Fri Sep 16, 2005 12:56 pm
Jon11582 wrote:If you got a V6, might be the fact that its actually using that gas to push some more power now, instead of retarding your engine so it can take regular gas. Been gunning it lately?
very good reasons bro. . . and also maybe you're having too much fun listening the airbox w/o a resonator. . . haha
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Nyyankees3511 » Fri Sep 16, 2005 12:58 pm
Thats possible, i got 80 miles since the full mark and right now its a lil higher than 3/4.
Nyyankees3511
Postby ChargedSolara » Fri Sep 16, 2005 10:49 pm
sounds normal. i used to get close to 400 on a tank.
2008 C6 LS3
ChargedSolara
Postby Jetfixer » Sun Sep 18, 2005 8:12 am
It's a total waste of money to use higher octane fuel than what is called for in any modern car. The sensors on the car determine how lean/rich to run the engine and how much advance is required on the timing to maximize the burn efficiency and to prevent knocking. The computer is calibrated for the recommended fuel. Using a higher or much lower fuel causes the sensors to go beyond their calibrated range. This is treated by the computer as a failure condition and it adjusts the engine accordingly, which is to say, it now defaults to a "limp-in" mode which will allow it to run, but at miserable performance as you have seen. Also, the K&N filter allows higher airflow. It takes awhile for the computer to adjust to it. Mine took a few start/run/stop cycles before it ran right again and I use the "drop-in" replacement K&N, not the CAK.
Jetfixer
Postby SPF 0 » Sun Sep 18, 2005 8:20 am
Jetfixer wrote:It's a total waste of money to use higher octane fuel than what is called for in any modern car.
One caveat I might add in to that truism is that while, for example, my '05 SLE <i>can</i> run on 87 octane (as per the manual), the full horsepower rating was done on 91+.
While it'll run just fine on the lower rated gas, you will lose HP.
NOTE: This is not applicable to every vehicle.
SPF 0
Postby Hefty » Thu Sep 22, 2005 2:25 pm
Make sure you didn't put the air filter in backwards. Also, double check that nothing got disconnected from messing with the throttle body. Your computer maybe running in closed loop mode if it has detected a sensor offline and this will impact driveability. Otherwise, wait till you put a few tanks through and see if it stays the same.
1999 Solara SE V6
2003 Nissan 350Z Track
Hefty
Postby Nyyankees3511 » Thu Sep 22, 2005 3:32 pm
the flat side goes up right?
Nyyankees3511
Postby methyl mike » Fri Sep 23, 2005 5:13 pm
I have a 99 v6 with over 100k what octane should i be using? I tend to use 87.
methyl mike
Postby mshearon » Sun Oct 30, 2005 5:44 pm
Using higher octane gas is like buying bigger tennis shoes to make you run faster.
mshearon
