SolaraGuy.com • View topic - knock sensor
knock sensor
knock sensor
Postby lazyboyz69 » Fri Sep 23, 2005 12:34 am
well guys i blew two knocks sensors....i'm located in socal... does anyone know where i can get the replaced for cheap or does anyone have any knock sensors they want to sell to me.... i miss boost.... and how much will you think it will cost to fix the knock sensors?
lazyboyz69
Postby Astro » Fri Sep 23, 2005 8:57 am
Man, that sucks! You should really invest in Jim's fuel kit upgrade and maybe fuel injectors...Even with the mods I got, I'll never run 6 lbs. I'm sticking with 5.5 lbs. :D Anyways, check with Gabe may still have some for $50 shipped or maybe he can still get some.
Check this thread...http://www.solaraguy.org/viewtopic.php?t=16684&highlight=knock+sensor
Postby Fletch » Fri Sep 23, 2005 9:40 am
CA gas blows too.
If I had to get all the way in there to replace those sensors, I'd find the GM/aftermarket ones, which I hear are a lot less likely to blow.
I think Gabe might be putting the aftermarket ones on.
2006 Legacy GT spec.B
Fletch
Postby StockSolara » Fri Sep 23, 2005 10:48 am
http://www.atsracing.net/ats_racing_knock_sensor.htm Check out this site for the ATS Racing Knock Sensor
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Alex(AUS) » Sun Sep 25, 2005 6:43 am
You can raplace the knock sensors yourself (if you are handy with some tools). In this case it will cost you the sensors and a day of work.
Alex
Alex(AUS)
