SolaraGuy.com • View topic - Do I need transmission flush?
Postby Kermy » Tue Sep 27, 2005 4:33 pm
Hi guys, so I got my Solara at 72000 miles. Have no idea what maintenance has been done before. One area that concerns is the transmission. I checked the transmission fluid earlier today and it came out to be a purplish color after I wiped it on a white napkin. Sorta like cherry juice on a napkin or grape juice on a napkin type of color. Also I smelled it and there was no burning smell. Very light oil smell.
What do you guys think? Flush?
Kermy
Postby BradOwens » Tue Sep 27, 2005 4:38 pm
it wouldnt hurt. also, do an oil change since u dont know the last time it had one
BradOwens
Postby StockSolara » Tue Sep 27, 2005 4:53 pm
Well the tranny fluid is redish color. . . you can spend the money for a power flush to get all of the fluids out or just drain the pan yourself but that will only replace like 3 quarts of the fluid. . . Our transmission holds a total of around 12 quarts of oil
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Solorange » Tue Sep 27, 2005 7:12 pm
I would get it flushed. I had the dealer do it and they charged me 60bucks.
Postby Kermy » Tue Sep 27, 2005 7:46 pm
Wow only $60? Dealer wanted $159. AAMCO wanted $120.
Kermy
Postby StockSolara » Tue Sep 27, 2005 8:04 pm
Solorange wrote:I would get it flushed. I had the dealer do it and they charged me 60bucks.
Are you sure it was a flush with them hooking it up to the machine and blasting all of the oil out of your tranny including the torque converter and not a drain and refill?
2000 Lexus GS400
StockSolara
Postby Sap Z » Wed Sep 28, 2005 6:34 am
yea..the best deal i found was at AAMCO for 99...and i found a $10 off idscount coupon on their website..
so its $90...thts next on my list...or maybe brakes..mine r sqeeking!
SapZ
V6 SE DWP
Sap Z
Postby SleeperSolara » Wed Sep 28, 2005 7:03 am
StockSolara wrote:Well the tranny fluid is redish color. . . you can spend the money for a power flush to get all of the fluids out or just drain the pan yourself but that will only replace like 3 quarts of the fluid. . . Our transmission holds a total of around 12 quarts of oil
Our tranny holds around 12 quarts??????
I only put in about 5 to 6 quarts.
Do i need to add more???
I thought it was about 8 quarts or something like that.
Idea
Postby JMSinMaryland » Wed Sep 28, 2005 6:34 pm
Go to your local Toyota dealerships websites. A lot of them have coupons for service. My service advisor tells me to collect from a few sites, bring it to her and she matches all the coupons =). Jon.
JMSinMaryland
Postby Solorange » Thu Sep 29, 2005 2:16 pm
Oops my bad, it was a drain refill. I went there and told them to change my tranny fluid. I figured a flush would have been part of that.
Postby quikz » Fri Sep 30, 2005 12:54 pm
i only put 5 quarts and that was still to much, save some money and do it your self.
01 blk SLE
quikz
Postby Yanks0114 » Fri Sep 30, 2005 7:32 pm
you are correct about the save you money part, but for the wrong reason - the tranny plus torque converter hold around 12-13 quarts.
Most places will just drain and refil the tranny, and not deal with the torque converter. This is basically useless. Get a full and refill, its well worth it
Postby SPF 0 » Fri Sep 30, 2005 7:57 pm
I concur that a fluid <i>flush</i> is a great idea, doubly so if the car came from The Snowbelt.
If the dealership will match coupons, I'd much rather have it done a dealership so that I can easily retrieve the car's service history at resale time.
It's very inexpensive insurance relative to having a transmission repair.
SPF 0
Re: Do I need transmission flush?
Postby krook » Fri Sep 30, 2005 8:31 pm
Kermy wrote:I wiped it on a white napkin.
every time you wipe you should flush.
krook
Postby ~Spadwaller~ » Fri Sep 30, 2005 9:23 pm
hahaahhaha :lol:
~Spadwaller~
