SolaraGuy.com • View topic - P0171 again!!
P0171 again!!
P0171 again!!
Postby ChargedSolara » Wed Sep 28, 2005 4:41 pm
Hey guys..i got sick of my cars popping codes so i picked up an OBDII scanner..they are on sale at autozone btw.
anyways my solara pulled the p0171 code, i referenced some old threads and checked out the symptoms..my car was running 5.5 psi b4 my tranny went out..during the rebuild i lowered boost back to stock 4psi. cleared the code and 200 miles later code pops up again. i just replaced o2 sensor less than a year ago, last time i pulled it out it was white which means lean.
so my question is...any other solutions to the problem? i do have the injen short ram but never had a problem for the 3 years i've had it on. maybe my MAF? heres the code set from haynes manual.
thanks!
P0171 – System too lean
· Loose air intake hose or duct
· Incorrect fuel line pressure
· Obstruction in injector
· Heated oxygen sensor malfunction
· MAP or MAF sensor malfunction
· ECT sensor malfunction
2008 C6 LS3
ChargedSolara
Postby StockSolara » Wed Sep 28, 2005 4:53 pm
Maybe you should consider upgrading your fuel system. . . With bigger injectors and fuel pump. . . retune the S-AFC
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby SC V6 » Wed Sep 28, 2005 5:07 pm
check your intake and make sure there is no oil in it
SC V6
Postby ChargedSolara » Wed Sep 28, 2005 5:13 pm
yeah i thought about it..but more money!! i got too many toys..i wanted to just daily drive the solara..
its weird cuz i never had this problem for the first 6 months i was boosting 4psi...any other thoughts?
2008 C6 LS3
ChargedSolara
Postby ChargedSolara » Wed Sep 28, 2005 5:53 pm
there is some oil in the intake filter and around the rubber hoses..what should i use to clean it off?? thanks
2008 C6 LS3
ChargedSolara
Postby SC V6 » Wed Sep 28, 2005 7:04 pm
check and make sure that you have a suction coming from the front valve cover hose.. it should be a suction.. if its not then you have damaged internals and blowby
SC V6
Postby lazyboyz69 » Wed Sep 28, 2005 7:45 pm
just put your stock intake back on....
lazyboyz69
Postby ChargedSolara » Wed Sep 28, 2005 8:18 pm
SC V6 wrote:check and make sure that you have a suction coming from the front valve cover hose.. it should be a suction.. if its not then you have damaged internals and blowby
how am i supposed to check that? thanks
2008 C6 LS3
ChargedSolara
Postby SC V6 » Wed Sep 28, 2005 8:25 pm
see if it sucks your finger or pushes air out
SC V6
start the car and do that
SC V6
Postby ChargedSolara » Wed Sep 28, 2005 8:26 pm
with the intake piping on or off
2008 C6 LS3
ChargedSolara
Postby CASTRO » Wed Sep 28, 2005 8:40 pm
I get the same problem with mine. Seems to get less as atime goes by. I've only had the charger on about a week and stock 4lbs with CAI. First 1-2 days the CEL would pop up at least 1-2 times each day with the p0171 code. I've got a realtime OBD2 scanner/gauge thing that lets me read and clear codes on the fly so i cleared it as soon as it poped up. So far I havent gotten it today, hope it doesnt bother me for a while.
CASTRO
Postby ChargedSolara » Wed Sep 28, 2005 8:46 pm
ur talking about the bigger piping from the valve cover right? or the smaller one?? the smaller one has a tight clamp on it..the bigger one isn't sucking my finger in.. its kinda pushing air. does tha tmean i have damaged internals?? $#(*$#$*!@#$!!!
2008 C6 LS3
ChargedSolara
Postby GenerationOne » Wed Sep 28, 2005 9:02 pm
:o :o :o :o :o
NOOOOOOOO!...............don't worry I have no clue :lol:
GenerationOne
Postby GenerationOne » Wed Sep 28, 2005 9:03 pm
PS isn't it a bad thing if you can fit your finger in your hose?
I'm sorry it's late and someone had to say it, i think? :lol:
GenerationOne
