SolaraGuy.com • View topic - brakes shaking
brakes shaking
brakes shaking
Postby prc » Wed Sep 28, 2005 6:57 pm
I just bought a 20001 solara sle. I've noticed that when i press on the brakes I can feel the brake pedal shaking. Also when I start braking at over 50mph the steering wheel starts to shake. I know this isnt normal and i was wondering if any of you guys know what the problem could be. Thanks
prc
Postby ThatVietGuy » Wed Sep 28, 2005 7:01 pm
Check your brake pads and rotors, especially since you bought your car used. The rotors might be warped or the pads might be worn down.
ThatVietGuy
Postby Paladin06Greg » Wed Sep 28, 2005 7:01 pm
It sounds like your rotors are warped. Better have a mechanic check your brakes.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby ClassySolaraGuy » Wed Sep 28, 2005 7:02 pm
I had that problem with my Jeep. The front passenger brake caliper was loose. After I tightend it, the shaking was gone. I would go have it checked out by a brake shop unless you know how to.
Just for precaution I would also check your brake fluid. :D
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby StockSolara » Wed Sep 28, 2005 11:20 pm
Almost 110% sure your brake rotor are most likely warped
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby ~Spadwaller~ » Wed Sep 28, 2005 11:36 pm
Take a picture.
~Spadwaller~
Postby SleeperSolara » Thu Sep 29, 2005 6:24 am
Yeah your rotors are warped.
My rotors are warped too, will need to change them.
Postby Sap Z » Thu Sep 29, 2005 7:26 am
like everyone said...ur rotors are gone. You will need new pads which probably run like $50 each. And then see if you can get the rotors fixed...or you might have to get new ones if the are pretty bad. I would suggest doing this ASAP since there may still be a chance for you to use your current rotors.
SapZ
V6 SE DWP
Sap Z
Re: brakes shaking
Postby SPF 0 » Thu Sep 29, 2005 8:43 am
prc wrote:I just bought a 20001 solara sle.
Wow! The 20001 models are out <i>already</i>?
This can't be good for the resale value on my 2005.
SPF 0
Postby SPF 0 » Thu Sep 29, 2005 8:49 am
As an aside, it's probably not a bad idea to also get your brake fluid changed.
BTW, this is my 400th post. Howzboutdat?
SPF 0
