SolaraGuy.com • View topic - Idle rattle noise after SC install
Postby WhiteSLEV6 » Thu Sep 29, 2005 5:09 pm
I did a search but couldn't find anything about this topic..
Anyways I just got my TRD Supercharger in in the mail 2 weeks ago and everytime i Idle, I hear this rattle noise coming from the engine, but when i start moving again the noise is gone. This normal?? or should I get it checked at toyota.
http://www.pbase.com/pearlwhiteslev6
TRD Supercharger, Injen Intake
Eibach springs next!
WhiteSLEV6
Postby SC V6 » Thu Sep 29, 2005 5:47 pm
do you have a boost gauge hooked up? cause it is probably the fitting coming off the S\C for reading boost hitting the strut bar.. if you don't have it hooked up its probably the auto tensioner which is normal
SC V6
Postby krook » Thu Sep 29, 2005 6:56 pm
sounds like auto tensioner
krook
Postby WhiteSLEV6 » Thu Sep 29, 2005 7:28 pm
No I don't have a boost gauge (looking to get one).. So you guys get that noise too at IDLE?? but anyways I have no clue what auto tensioner is. Can any of u guys explain what it is? But man.. I feel the torque difference from a stock 1MZ-FE to SC.
Anyways looking to hit the track this week.. What times are u guys thinking i can hit with just SC and Intake and possibly brake launch.
WhiteSLEV6
Postby StockSolara » Fri Sep 30, 2005 12:48 am
If you have been pushing your car hard than you probably have the timing belt tensioner and idler pulley prematurly break and the timing belt is stretched out. . . That is what happen to me. . . it will make that rattling noise when it is in idle. . . So i had those parts replace along with the Solara and it runs like a champ :D
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Fletch » Fri Sep 30, 2005 3:20 am
It sounds like a bearing that is going to wear out to me, but this is normal, just the way it sounds. I have heard that replacing the mineral oil in the spindle head with synthetic oil from a S/C oil change kit will quiet it down a little.
2006 Legacy GT spec.B
Fletch
Postby Hsakuragi » Fri Sep 30, 2005 9:15 am
ya, that's normal...don't worry
Hsakuragi
Postby JoeB » Fri Sep 30, 2005 9:39 am
That noise is normal. What you are hearing is the gears in the sc. I was a little worried about that when I got mine installed too. -JoeB
JoeB
Postby bunthy » Fri Sep 30, 2005 9:44 am
yeah, its normal. For me, the sound actually disappeared.....sounds like stock now at idle, but whines like hamster when boosted. :P
bunthy
