SolaraGuy.com • View topic - Transmission oil question?
Postby Nyyankees3511 » Sun Oct 02, 2005 2:45 pm
How much oil does it take? How should i fill it, with the engine running?
Nyyankees3511
Postby bassthrive » Sun Oct 02, 2005 8:07 pm
Check your manual, and no.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby StockSolara » Sun Oct 02, 2005 9:45 pm
If you just drain out the oil pan. . . it's only about 3 quarts. . . just fill it like how you would with engine oil. . . Before you drain you should drive it around so the oil will be hot so than it will drain better
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Nyyankees3511 » Mon Oct 03, 2005 12:31 pm
o ok i thought i read somewhere that it takes like 10 quarts.
Nyyankees3511
Postby Yanks0114 » Mon Oct 03, 2005 8:02 pm
Nyyankees3511 wrote:o ok i thought i read somewhere that it takes like 10 quarts.
You are correct. It takes roughly 10-12 quarts for the transmission and torque converter. I would do a flush and refil.
If you just drain and refill 3 quarts, that is only 1/4 of the fluid and its not going to make much of a difference.
BTW - great sn
Postby StockSolara » Tue Oct 04, 2005 12:00 am
^^^ fa sho
2000 Lexus GS400
StockSolara
Postby Nyyankees3511 » Tue Oct 04, 2005 4:00 am
Thanks yanks i like yours too. Yeah the oil seems bad its like a light black color.
Nyyankees3511
