SolaraGuy.com • View topic - Replacing o2 sensor
Replacing o2 sensor
Replacing o2 sensor
Postby RichD978 » Mon Oct 03, 2005 5:00 am
is that fairly easy to do on our cars? any tips/advice/wisdom
RichD978
Postby RichD978 » Mon Oct 03, 2005 5:12 am
went to advanceautoparts.com
theres so many types, can someone help me out as to which one to get ? Jackass Jeff?
RichD978
Postby PhreakdOut » Mon Oct 03, 2005 5:22 am
I'm not sure what's on the Gen 1's, but in general, universal O2 sensors are classified by the number of wires going to the sensor. (Two, three or four) Of course, going with a factory sensors will be the easiest since there will be no wire splicing. (Naturally it would be the most expensive too.)
Getting them loose is the hard part. A cheap propane is a good investment.
Postby RichD978 » Mon Oct 03, 2005 5:31 am
well i just got an aftermarket exhaust about 2 weeks ago so it shouldn't be too hahrd to get out yet i suppose
For vehicle: 1999 TOYOTA SOLARA V6 3.0 Liter FI (change)
10 parts found.
Description Availability * Price Buy
Bosch 15217
OE Type; 4 Wire; Heated; Upstream Sensor; Calif; O2 sensor located in rear manifold/exhaust pipe; Check/Replace Interval 100 K Miles
1 Year Replacement Warranty
Ships in 1 day
Weight: 3 lbs. 10% off!
Now $371.59
Bosch 15733
Universal Type; 4 Wire; Planar; Downstream Sensor; Check/Replace Interval 100 K Miles
Find in a store
Ships in 1 day
Weight: 2 lbs. 10% off!
Now $66.57
Bosch 15733
Universal Type; 4 Wire; Planar; Upstream Sensor; Except Calif; Two required; Check/Replace Interval 100 K Miles
Find in a store
Ships in 1 day
Now $66.57
Bosch 15733
Universal Type; 4 Wire; Planar; Upstream Sensor; Calif; Two required; Check/Replace Interval 100 K Miles
Find in a store
Ships in 1 day
Now $66.57
Bosch 13353
OE Type; 4 Wire; Heated; Downstream Sensor; Check/Replace Interval 100 K Miles
Ships in 1 day
Weight: 0.3 lbs. 10% off!
Now $121.39
Bosch 13355
OE Type; 4 Wire; Heated; Upstream Sensor; exc. Calif; Two required; Check/Replace Interval 100 K Miles
Ships in 1 day
Now $115.99
Bosch 13998
OE Type; 4 Wire; Heated; Upstream Sensor; Calif; O2 sensor located in front manifold/exhaust pipe; Check/Replace Interval 100 K Miles
Ships in 1 day
Now $339.19
Borg Warner OS1198
Oxygen Sensor: Rear; Inspect Or Replace Every 100,000 Miles
1 Year Limited Warranty
Ships in 3 days
Now $107.09
Borg Warner OS957
Oxygen Sensor: Front; W/ M.T.; W/ Stamping No. 89465-33180; Two Used; Inspect Or Replace Every 100,000 Miles
Ships in 3 days
Now $116.09
Borg Warner OS968
Oxygen Sensor: Front; W/ M.T.; W/ Stamping No. 89465-06030; Two Used; Inspect Or Replace Every 100,000 Miles
Ships in 3 days
Now $116.09
these are the results for oxygen sensors for my car. You can say im somewhat confused
RichD978
Postby Fletch » Mon Oct 03, 2005 6:33 am
OE cost me $135 ea, had it them installed along with some other work. Without installing them myself, I guess I'd recommed a crow's foot at a minimum. I have the part# at home if somebody doesn't come up with it sooner.
2006 Legacy GT spec.B
Fletch
Postby RichD978 » Mon Oct 03, 2005 8:51 am
do the 2 sensors share the same part number?
RichD978
Re: Replacing o2 sensor
Postby nj99solara » Mon Oct 03, 2005 9:03 am
RichD978 wrote:is that fairly easy to do on our cars? any tips/advice/wisdom
You should contact a toyota dealer and see if they can give you a part # because as far as I know the sensors are different depending on your vin#. You also will need to know which one is bad, I believe we have 3.
One is in front when you open the hood another is between the engine and the firewall,and there is another under the car .
When I needed one it was the one by the firewall it wasn't hard at all but I did get my arm and hand scraped and cut cuz it's a tight area in there.
I had it scanned for free at autozone and I went to the dealer with the code and my vin# and they sold me the part and told me which sensor was the bad one from the code I had.
To save myself any trouble I brought mine from the dealer and it cost me $166.00,the universal is alot cheaper (at least half) but I believe "you get what you pay for".
-4500k HID Bi-xenon kit
-4500k HID Fogs
-5% Tint in rear
-Tinted Stock Taillights
-Shaved Emblems
nj99solara
Postby RichD978 » Mon Oct 03, 2005 6:14 pm
i was reading the haynes manual... you have to take the driver seat off ?!?
RichD978
Postby RichD978 » Tue Oct 04, 2005 6:29 am
bump... dealer ship tried to sell me a new cat converter.
http://autozone.com/servlet/UiBroker/?UseCase=C001&UserAction=answerRequiredQuestion&Parameters=%7C%7ESENSOR+LOCATED+AFTER+CATALYTIC+CONVERTER&PageSync=1
would this work? the dealer said my o2 sensor has cali emmisions on it.... but when i found that part on advance auto parts they didn't say anything bout ca emmissions... help me out guys
RichD978
Postby RichD978 » Tue Oct 04, 2005 6:43 am
^^ link doesn't work but just look it up 99 v6 solara .. .after cat coverter o2 sensor
RichD978
Postby RichD978 » Tue Oct 04, 2005 7:38 am
bump... if it has CA emissions, and i dont live in CA, would i have to worry about getting one that does not clearly state CA emissions?
RichD978
Postby Ford_Fixorrepairdaily » Tue Oct 04, 2005 8:12 am
How come youre replacing your o2 sensor?
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
Postby RichD978 » Tue Oct 04, 2005 8:15 am
im thinking it burned out cause i recently installed the greddy evo 2 exhaust and the diff. in heat might have burned it out (i got a CEL a week afterwards)
RichD978
Postby Ford_Fixorrepairdaily » Tue Oct 04, 2005 8:50 am
I had the same prob, turned out that it was just loose. Check the cel code to be 100%
