SolaraGuy.com • View topic - Problem with starting when warm? Help
Postby Nyyankees3511 » Tue Oct 04, 2005 12:56 pm
It seems like i have a problem when starting the car when its warm. It starts soo fast and a couple of times i went to restart just after shuting it off and it starts and shuts off. I thought it was my battery and i was wrong. Its wierd. Let me know.
Nyyankees3511
Postby Mole » Tue Oct 04, 2005 4:38 pm
hmmm it dies after a restart?
are you cranking over long enough ?
Postby Nyyankees3511 » Tue Oct 04, 2005 4:41 pm
It does it sometimes, it starts fine but it dies right away and when its hott i overturn it, it starts instantly which ive never seen before.
Nyyankees3511
Postby Grazi07 » Tue Oct 04, 2005 5:11 pm
have your starter tested maybe? I'm having a hard time understanding what the problem is exactly....
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby Nyyankees3511 » Tue Oct 04, 2005 5:15 pm
When the car is cold it starts up fine but i was at a red light once and i shut off the car and restarted it and it wouldnt start right i tried like 3 time before it started. The problem is only when the car is hot. I live in RI too.
Nyyankees3511
Postby Hefty » Thu Oct 06, 2005 1:37 pm
Not much to go on here but sounds like a fuel problem. Do you click your gas cap at least three times when you fuel up your car? The gas cap has to make a good seal so that the proper vacuum is built up in the tank otherwise the pump will not work effectively. Also, could be having an engine deposit problem. I'd run a bottle of RxP through your car to see if that helps. It eliminates deposits, cleans injectors and intake valves, and reconditions your emission control equipment.
1999 Solara SE V6
2003 Nissan 350Z Track
Hefty
