SolaraGuy.com • View topic - Squealing
Squealing
Squealing
Postby SpikedMantis » Thu Oct 06, 2005 2:27 pm
This started about last week. Whenever I'm NOT pressing the brake, my car squeals when above 20 mph. Even when I accelerate it still squeals. Does anyone know what's going on? I'm going to bring it in, but I just want an idea of what might be happening.
SpikedMantis
Postby Ford_Fixorrepairdaily » Thu Oct 06, 2005 2:29 pm
Where is the squeal coming from?
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
Postby SpikedMantis » Thu Oct 06, 2005 2:30 pm
Not sure, but I can hear it even when the windows are rolled up. I'm thinking it's coming from the engine.
SpikedMantis
Postby WTF?? » Thu Oct 06, 2005 3:58 pm
Might be the belts if it happens upon start-up
Retired... its been fun Image
WTF??
Postby Ford_Fixorrepairdaily » Thu Oct 06, 2005 3:59 pm
Have you changed your timing belt? Not sure what it could be, but have it checked out asap.
Postby dominoSLEV6 » Thu Oct 06, 2005 4:10 pm
Does it sound like a flock of angry bats? If so I'm gonna point my finger at the belts as well.
Haha!
No, but seriously it's probably the belts. Althoguh I couldn't explain why it doens't happen under 20MPH.
-chris
dominoSLEV6
Postby SolaraBlue » Fri Oct 07, 2005 11:15 am
its either your belts or your power steering.
Postby StockSolara » Fri Oct 07, 2005 1:18 pm
One of your belts might be loose. . . usually squeaking of belts is a sign of slipping
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby SpikedMantis » Fri Oct 07, 2005 1:35 pm
Well, I took it in today and the tech said that I need a new timing belt and my brakes don't have shims, whatever that means. Basically, it's going to be about $675. :cry:
SpikedMantis
Postby Sap Z » Fri Oct 07, 2005 2:01 pm
well...its its sqeeking - it might be the brakes
if its screetching ! - belts
SapZ
V6 SE DWP
Sap Z
Postby PhreakdOut » Fri Oct 07, 2005 2:20 pm
$675? I hear that squealing again! Ouch!
Postby dominoSLEV6 » Fri Oct 07, 2005 4:58 pm
Sap Z wrote:well...its its sqeeking - it might be the brakes
It's nice to see someone with an appreciation for the fine line between screetching and squealing.
Anywho, 675 for what? the now timing belt? Or a new timing belt and brakes?
All installed?
-chris
dominoSLEV6
Postby xavier » Sat Oct 08, 2005 9:40 am
Im guessing that its the soft metal wear indicator signaling that your brakes are worn out.
xavier
Postby Ford_Fixorrepairdaily » Sat Oct 08, 2005 5:30 pm
You can use trd brake pads which dont require shims.
