SolaraGuy.com • View topic - V6 engine misses
V6 engine misses
V6 engine misses
Postby mshearon » Fri Oct 07, 2005 7:29 am
I have a 99 Solara SLE with a V6. Recently the engine starting missing once in a while. I took it to the dealer and they told me it needed plugs and wires for $380.00. I changed the plugs and wires myself (did not remove the plenum) but the hesitation is still there. One time I got an error code that read #6 cylinder missfire. I swapped the ignition coils between 5 and 6 hoping to move the problem hence verifying the problem. The engine stilll misses but I haven't seen another error code. Can anyone tell me what the problem most likely is? I'm leaning towards a faulty injector. I measured the injector resistance an all 3 injectors across the front and got 17 ohms each. I've also cleaned and inspected the throttle body and all the vacuum lines I can find. Thanks in advance.
mshearon
Postby SleeperSolara » Fri Oct 07, 2005 7:44 am
It somethin' wit the spark plug wire to the #6 cylinder.
Postby ClassySolaraGuy » Fri Oct 07, 2005 7:46 am
I'm not sure if the V6 has a cap/rotor but my Jeep had the same problem. My cap was loose and the rotor inside was cracked.
Fuel injectors could be the problem like you said too!
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby Turbosolara » Fri Oct 07, 2005 8:26 am
I thought you v6 guys had direct ignition? (distributorless ignition). I think your coil pack is bad, if you replaced your wires and spark plugs correctly. what kind spark plug did you put it in, you sure it has right gap?
Postby SC V6 » Fri Oct 07, 2005 8:29 am
yeah... no distributor.. make sure all the connections to the front coil packs are connected and bolted to the valve cover
SC V6
Postby StockSolara » Fri Oct 07, 2005 1:20 pm
If everything is right you most likely will need some new coil packs. . . contact Greg *Paladin06Greg* I remember he was selling some brand new OEM ones
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Monkeyman » Sun Oct 09, 2005 6:23 pm
Make sure the ground for the existing coil pack is good. It may look "ok" but clean it up anyways. A bad ground can cause intermittent problems. It is not likley the cause, but better to check it then spend money on a new coil only to find that it was the ground all along. The ground spot should be clean and without corosion.
Hope this helps.
Monkeyman
Postby mshearon » Fri Oct 28, 2005 12:31 pm
Thanks for all the help...the problem ended up being an ignition coil pack sparking to ground. I ended up having the dealer fix it. It cost $93 for the coil pack and $98.00 to do the work (1 bolt and 2 connectors). I felt I should have gotten a kiss, but am glad my car runs great again.
mshearon
Postby drock03 » Wed Feb 08, 2006 10:58 am
Where are the coil packs located and are there 3 or 6 of them???
drock03
Postby StockSolara » Wed Feb 08, 2006 11:09 am
drock03 wrote:Where are the coil packs located and are there 3 or 6 of them???
It's the three rectangular looking things in the front of the engine
2000 Lexus GS400
StockSolara
Postby drock03 » Wed Feb 08, 2006 11:15 am
Bolted over the plugs?
drock03
Postby mshearon » Wed Feb 08, 2006 11:23 am
Yes they connect to one plug directly and have a plug wire that goes around to the firewall side of the engine.
mshearon
Postby drock03 » Wed Feb 08, 2006 11:55 am
Thanks, that's what I thought
drock03
Postby Fratsgotasolara » Wed Feb 08, 2006 1:09 pm
its like 70 a coil
"You may not know me, But your girlfriend does!" -Delta Chi OSU
Fratsgotasolara
