SolaraGuy.com • View topic - Passenger Headlight Out
Postby thealkimo » Tue Oct 11, 2005 10:43 pm
recently my passenger hid went out and i found that one of the cables was rubbing against something hot and seared the cable down to a point where it can no longer hold electrical current...
and now i have removed the bulb and ballast to send back to have it replaced and threw in a stock halogen bulb and now that light doesn't turn on at all...
i checked the plug and its fine and then i checked the fuse and it appeared to be just fine...anyone know what is going on with this???
thealkimo
Postby krawzyazn » Tue Oct 11, 2005 11:43 pm
I don't think this is covered under warrenty
did you check the fuse near the battery
Postby ChargedSolara » Wed Oct 12, 2005 1:28 am
my driver side HID is out, and i checekd connectiosn/fuses everything looks okay. sometimes the dead HID will come on and be very very dim and blue...i think we have different issues though.
did you do the instal yourself? where did u mount the ballast?
2008 C6 LS3
ChargedSolara
Postby thealkimo » Wed Oct 12, 2005 3:04 am
i checked the fuse near the battery and nothing appears to be wrong...
i mounted the ballast to the chassis near the abs and used plenty of insulation...
man, i hope toyota doesn't rip me off for this one if i can't get it figured out...
thealkimo
Postby Sap Z » Wed Oct 12, 2005 6:45 am
crap man..dont know wat it is but now i'm worried bout mine. Gonna check it when i get out today
keep us posted bro
SapZ
V6 SE DWP
Sap Z
Postby SleeperSolara » Wed Oct 12, 2005 7:18 am
Check if the plug is all the way in.
Also the connection of the plug for those 3 wires.
That's all i can think of.
