SolaraGuy.com • View topic - Supercharger Removal Help!!
Postby Paladin06Greg » Fri Oct 14, 2005 8:43 pm
My daughter and I were just about to remove my SC and only had one bolt left to remove. Standing in front of the car, on the left hand side, there is a bolt on the backside of SC that goes through a black metal bracket. The head of that has been rounded of so bad from prior removals and installs that I can not even get a socket to stay on it. So yea, now I'm pissed.
Anybody got an idea how in the hell I might get that bolt out. As you can see if you have an SC there is little to NO room back there to work.
Steamin in the desert!!
Greg
Paladin06Greg
Torqued Solara
Torqued Solara
Postby DatSRBoi » Fri Oct 14, 2005 9:28 pm
My guess is to use a clamp wench........... Good luck bro. Wish I can help you.
Postby ~Spadwaller~ » Fri Oct 14, 2005 9:30 pm
Cut in with a dremel in the middle and use a screwdriver to unscrew where you made the cut. Hope that helps :-?
~Spadwaller~
Postby Alex(AUS) » Sat Oct 15, 2005 3:17 am
Undo the bolt at the bottom of the black rod and take it all out.
Alex
Alex(AUS)
Postby Vampire » Sat Oct 15, 2005 3:54 am
If you have the bolt off that holds the power steering pipe on that is what I would do. You do have to crawl under there though, and reach up. May not have room between the SC and firewall to do anything else.
Alex(AUS) wrote:Undo the bolt at the bottom of the black rod and take it all out.
Alex
Paul
02 Solara SE V6 5spd SC
00 Camry LE V6 Auto SC
Vampire
Postby SC V6 » Sat Oct 15, 2005 6:57 am
they make sockets that are for stripped bolts.. might as well go pick up the set
SC V6
Postby Paladin06Greg » Sat Oct 15, 2005 8:09 am
Hey guys I really appreciate the support. I was so mad last night I had trouble sleeping.
First I'll go under her, then I'll try the special socket. No room to do anything while the SC is installed on the car.
Again thanks guys. 8)
Paladin06Greg
Torqued Solara
Torqued Solara
Postby JAYDEE23 » Sat Oct 15, 2005 8:35 am
SC V6 wrote:they make sockets that are for stripped bolts.. might as well go pick up the set
yeah the special socket has groves that will cut into and hopefully seat.
i have not had much luck with these sockets but they do work sometimes.
the dremel method(slot bolt then use flat head to remove) works well as long as you make sure there is enough meat on the bolt head left to stand up to the amount off pressure needed to remove it..
if all else fails and you destroy the head try tapping the screw around w/ a center punch
if that fails drill a hole and use an extractor
if that fails..go to the liquor store :lol:
JAYDEE23
Postby Yanks0114 » Sat Oct 15, 2005 9:47 am
LOL, thats classic
I'm not sure if you have the room to do this, but you can always take a smaller socket and then use a mallet to hammer it on. This may destroy the socket which is why you want to buy a craftsman set because it has a lifetime gaurentee
Postby Paladin06Greg » Sat Oct 15, 2005 12:57 pm
You are right. I found a set in Auto Zone. Going to give her a shot after I rest my damn back for awhile. Hurts like a SOB after last night attempt to remove my SC.
Thanks again for the help!~
Greg A
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SC V6 » Sat Oct 15, 2005 1:07 pm
Paladin06Greg wrote:You are right. I found a set in Auto Zone. Going to give her a shot after I rest my damn back for awhile. Hurts like a SOB after last night attempt to remove my SC.
Greg A
not a problem.. good luck
SC V6
Postby Paladin06Greg » Sat Oct 15, 2005 8:11 pm
Well the tool worked life a charm. I got the SC off and found several concerning problems. The metal tube on the back side of the SC that is hooked to the PCV valve by rubber hose was broken free of the SC housing. I could spin it 360 degrees with my finger.
Once out there was oil coming out of the SC and when rotated by hand the SC was very noisy and slightly rough. I also noted some backlash when rotating the pulley by hand. More then what I remember when it was new.
I did not notice any metal shavings in the SC or in the engine intake. I have a very small magnetic tool that I stuck in all openings and it came out clean on each one. Tomorrow I'll pull and inspect my metal, reuseable oil filter just to make sure.
Maybe, just maybe I got lucky. Several other problems were found not SC related but they will need to be corrected before I put her back together..
Waiting on my new SC.
Thanks again for all the help.
Paladin06Greg
Torqued Solara
Torqued Solara
supercharger
Postby Vi3tT3kNiqz » Sat Oct 15, 2005 8:58 pm
hey greg, so you've got a new charger to replace your old one. what are you going to do with the old one. I'm interested in buying it if you can give me a good price on it. I'm a college student and would like my car to have more power. Please help a poor person out. lol. Thank you, let me know.
Vi3tT3kNiqz
Re: supercharger
Postby Paladin06Greg » Sat Oct 15, 2005 9:08 pm
Well I don't have it yet but I will soon. I plan to have the old one rebuilt and then put it up for sale. There are a number of folks who are interested. I will sell it at a very fair price.
Vi3tT3kNiqz wrote:hey greg, so you've got a new charger to replace your old one. what are you going to do with the old one. I'm interested in buying it if you can give me a good price on it. I'm a college student and would like my car to have more power. Please help a poor person out. lol. Thank you, let me know.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby thakidd » Sat Oct 15, 2005 11:18 pm
Alex
id give this a try greg seems like it should work
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
