SolaraGuy.com • View topic - What should idle be at?
Postby Nyyankees3511 » Thu Oct 20, 2005 3:35 pm
Hey guys, ive noticed lately that my idle when fully warm is 1 bar below 1000 or a little less but never 2 bars is that normal? Also how do i clean the mass air flow sensor? I just hit 100k on the odo what else should i check, i replaced the sparkplugs, cleaned the throttle body. Maybe i should change the fuel filter where can it be found? What oil filter should i use other than toyota. Any other advice would be appreciated. Thanks guys.
Nyyankees3511
Postby BradOwens » Thu Oct 20, 2005 3:44 pm
it should idle a lil below 1000. anywhere is fine(mine idles at like 700) unless its really low. you should most deff get an oil change. other than tht ur good
BradOwens
Postby NeFaRiOuS_SLE » Thu Oct 20, 2005 4:01 pm
On the same note, is it normal for the Gen1 V6 to idle and not in gear at 1800 when you first start it with noxious gas fumes? When it warms up, it's completely regular (about 700 RPM and you can't smell a damned thing).
Postby Solorange » Thu Oct 20, 2005 7:40 pm
Mine idles at 600rpm
Postby Astro » Fri Oct 21, 2005 9:48 am
Mine's at 750rpm.
Postby DatSRBoi » Fri Oct 21, 2005 11:32 am
Mine idles at 0... Ops no wonder... *EEEEE VROOM VROOM* Ah thats better.. its at 750..
Postby JAYDEE23 » Fri Oct 21, 2005 1:39 pm
if you hit 100k and havent done the "BIG 70-80k" tune up then prepare to spend some cash..i dont have time to list right now but i will later
2 of the more expensive issues would be the timing belt and water pump which you should do together to minimize costs..
and i am about to change my fuel filter also ill check where it is..recommended every 30000 for the fuel filter
JAYDEE23
Postby Nyyankees3511 » Fri Oct 21, 2005 2:24 pm
Fuel filter is under the intake, you should be able to see it. Where do you get the fuel filter from? Whats the best way to change it? Thanks
Nyyankees3511
Postby NeFaRiOuS_SLE » Sun Oct 23, 2005 9:32 pm
bump
