SolaraGuy.com • View topic - motor mount
motor mount
motor mount
Postby Grnarowana » Fri Oct 21, 2005 4:02 pm
How much would a replacement motor mount cost? This is for a 99' Solara v6.
And this would be for the metal clicking sound whenever I go over bumps and my friend said it probably is the motor mount.
True?
Grnarowana
Postby SC V6 » Fri Oct 21, 2005 4:23 pm
depends on which one it is
SC V6
Postby zoni » Sat Oct 22, 2005 10:03 pm
more like struts... or upper strut mounts.
a motor mount would be when you pound on the gas, the motor would rock hard
and you will get more wheel hop as well with bad mounts.
did you put lowering springs on? if so, its probably the struts. try standing outside your car, and listening when you push down and pull up on the wheel well... it might do it then too...
5s auto swapped to 1mz std / Turbo
zoni
Postby Yanks0114 » Sun Oct 23, 2005 10:55 am
i'm with zoni, it sounds like the strut mounts.
Search for "Strut Mount"
Its a common problem with this platform
Postby zoni » Sun Oct 23, 2005 2:21 pm
yeah everyone complains of strut mount issues... i have never had a problem with mine, i just have electrical woes every time i work on it.
zoni
click
Postby Sentinel » Sun Oct 23, 2005 2:35 pm
I had (perhaps) the same problem. The guys that did my lowering said my "strut hat" was loose, and tightened it, but if it came back, they said I should replace it. I checked for loose bolts everywhere I could before I took it in, but I don't know where the strut hat is. I imagine it is beneath the cover on the top of the strut, B/C I tried to turn the 3 bolts that hold the strut on, and they were all solid.
Sentinel: HATES random pops, rattles and other funny noises anywhere in his car.
Sentinel
Postby zoni » Sun Oct 23, 2005 5:10 pm
its the piece that has the 3 studs on it, with the 1 big nut that connects to the strut.
zoni
