SolaraGuy.com • View topic - PCV valve?
PCV valve?
PCV valve?
Postby Nyyankees3511 » Fri Oct 21, 2005 9:55 pm
Where is the PCV valve located? I just want to make sure its not stuck closed or open.
Nyyankees3511
Re: PCV valve?
Postby StockSolara » Sat Oct 22, 2005 1:24 am
Nyyankees3511 wrote:Where is the PCV valve located? I just want to make sure its not stuck closed or open.
it's in the rear right under the intake manifold on the passenger side
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Nyyankees3511 » Sat Oct 22, 2005 7:02 am
Thanks, but what controls the vacumm to start and shut? Thanks
Nyyankees3511
Postby Jon11582 » Sat Oct 22, 2005 7:35 am
Take it off
If it rattles when you shake it, its broke.
If you go to the trouble of getting it off, you might as well replace it even if its not broken, since its like a 5 dollar part.
2000 Black Solara SE
Jon11582
Postby Nyyankees3511 » Sat Oct 22, 2005 7:58 am
Ok so just take out the black L connector from the engine to the hose in back of the engine on the passenger side? Just one question why would it rattle?
Nyyankees3511
Postby StockSolara » Sat Oct 22, 2005 3:37 pm
Nyyankees3511 wrote:Ok so just take out the black L connector from the engine to the hose in back of the engine on the passenger side? Just one question why would it rattle?
cause the valve might be broken for the air to come out
2000 Lexus GS400
StockSolara
Postby bassthrive » Mon Oct 24, 2005 3:04 pm
Huh? Rattle? What? If it doesn't rattle then that means it is gummed up and stuck in one position. Use a piece of old hose to blow air through the valve. You should only be able to get air to move through the valve one way. If it goes both ways or no air gets through at all, or if the part is just old (30k+) then it is time for a new part.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Jon11582 » Mon Oct 24, 2005 5:08 pm
bassthrive wrote:Huh? Rattle? What? If it doesn't rattle then that means it is gummed up and stuck in one position. Use a piece of old hose to blow air through the valve. You should only be able to get air to move through the valve one way. If it goes both ways or no air gets through at all, or if the part is just old (30k+) then it is time for a new part.
I forget if the rattle is bad or not, but I think its a moot point. If you take the time out to actually take it out and check it, you might as well replace it, whether its used and still working, or bad. Whats it, a 3-5 dollar part? at least for my I4 it was, not sure about the 1MZ, but I'm sure its not too much more if it is more.
EDIT - I read up. You should be able to blow in one side and feel the air go through, and blow in the other side and NOT feel it go through the other way. The valve lets air in one way only.
Jon11582
Postby JAYDEE23 » Tue Oct 25, 2005 2:35 pm
i paid $3..takes abouty 30 seconds to do including poping the hood and scratching your ass
JAYDEE23
