SolaraGuy.com • View topic - Steering wheel shakes at higher speed...
Postby tglove » Wed Oct 26, 2005 10:00 am
i've searched on the boards for this but haven't found an answer....as opposed to the steering wheel shaking when braking (ie. brake pads/rotor wear)...i'm having the reverse problem of steering wheel shaking when speeding up....??! and there's a time element too...once i start a trip and accelerate to ~30-50 mph theres a considerable shake/vibration in the steering wheel but once i accelerate further into highway speeds (60-80 mph) the vibration disappears....
any ideas?
tglove
Postby Jetfixer » Wed Oct 26, 2005 10:03 am
Get your tires balanced
Jetfixer
Postby Jon11582 » Wed Oct 26, 2005 10:03 am
I think either your front wheels need rebalancing/realignment or your front lugs need to be tightened. If you have aftermarket rims, you may need hub rings.
Vibration through the steering wheel is a front wheel issue though. Through the seat is rear wheels.
2000 Black Solara SE
Jon11582
Postby StockSolara » Wed Oct 26, 2005 11:50 am
^^^ Yeah what those two said
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby tglove » Wed Oct 26, 2005 12:32 pm
thanks guys...i actually need some new tires...been driving the stock tires and am around the 60k mile mark.....sounds like you guys are confident it's a front end issue...so i'll get it looked at once new tires are on....
i'll post in a separate thread about any recommendations anyone has for good tires....
tglove
Postby NeFaRiOuS_SLE » Thu Oct 27, 2005 1:04 am
Or the rim is bent out of shape. I took a turn too fast in my old SenCrap and hit a curb and I couldn't go above 30 without feedback... Since I hated the car and I was broke, I just put that tire in the back wheel and replaced the lower control arm (since that got bent, but didn't bother with body repair) :D, although the ride quality became bad too, but I just said it was because it was an economy car.
