SolaraGuy.com • View topic - Brake light indicator in dash
Postby mikee7 » Wed Oct 26, 2005 12:43 pm
Has anyone experienced a faulty brake light indicator? My brake light indicator occassionally comes on and goes off like when turning corners, etc. The brake master cyclinder reservior is full and the brake pads are about 60% gone. I also have a winshield washer light stuck as well. I cannot find the connection to disconnect it and reset it.
mikee7
Postby StockSolara » Wed Oct 26, 2005 9:47 pm
You should double check and look really carefully at the brake fluid resivoir. . . That is what I thought too but when I look closely is was barely below a line by a little bit and I added a little bit of fluid and it went off. . . The washer fluid is probably going out too so when you turn the water might be all on one side and trip the low fluid sensor
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby mikee7 » Sun Oct 30, 2005 9:13 pm
StockSolara wrote:You should double check and look really carefully at the brake fluid resivoir. . . That is what I thought too but when I look closely is was barely below a line by a little bit and I added a little bit of fluid and it went off. . . The washer fluid is probably going out too so when you turn the water might be all on one side and trip the low fluid sensor
Wanted to say thanks for the suggestion on the brake fluid reservior issue. The fluid was just barely under the full mark but I took your suggestion and added fluid and guess what, it cured the porblem. As for the windshield washer fluid issue, the dash board indicator light stays on all the time and it is not due to the fluid levels. I need to find the connection from the sender unit to the reservior so I can disconnect it and hopefully reset the darn thing. Any ideas where the connection is??
mikee7
