SolaraGuy.com • View topic - Help, A/C blower fan
Postby kat » Wed Oct 26, 2005 6:21 pm
blower on Heat/ A/C unit only operating at low speed. Car has the auto/temp control system. When I increase fan speed indicators on display appear to go up, but fan speed does not increase. HELP!
kat
Re: Help, A/C blower fan
Postby WTF?? » Wed Oct 26, 2005 6:56 pm
Theres a resistor behind the HVAC that you will need to have replaced... no need to go to a dealer on that and have a local shop do it for cheaper unless youre electronically inclined.
kat wrote:Car has the auto/temp control system.
I believe you have the SLE digitial climate control... the resistor may cost a bit more than the SE models' resistors... Im not sure since ive never had to replace it...
good luck!
Retired... its been fun Image
WTF??
Postby kat » Wed Oct 26, 2005 8:19 pm
I found a resistor in the blower housing and I checked with a meter. I got 3.6 ohms on the meter. What I have read in the past was if the resistor was bad it would be blown. This one doesn't seem to be blown. Is there more than one resistor?
kat
