SolaraGuy.com • View topic - fuel system release under rear seat 2000 v6? help?
Postby JAYDEE23 » Sun Oct 30, 2005 9:07 am
i am changing my fuel filter today..i could find much searching this board
anyway looks like it is right in front of/below the brake fluid resevoir. my question is the manual say to release the fuel pressure by removing the back seat gaining access to the hole/sending unit?..then it referes me to a chapter that refers me back to the beginning
book screw up
anyway is this necessary to relive the pressure from here or can i justr wrap or cover the filter itself and relieve the pressure from there
any help is appreciated..last warm day in new england probably :-?
JAYDEE23
Postby jhenty » Sun Oct 30, 2005 9:27 am
i've never heard that, i just go under the hood and get that baby off and put the new one on. Although I must tell you the two fuel filters I've done have taken forever because it sucks to get the hose off the filter, its on tighter than anything I've ever seen. Just make sure you use two wrenches, one for the fuel filter to hold it, and another to uncrew the hoses bolt. There will be some fuel that probably shoots out the hose so close your mouth, haha. Good luck.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby JAYDEE23 » Sun Oct 30, 2005 9:40 am
i guess thats the point of releasing the pressure..probably makes the bolt easier to get off too?
thanks
JAYDEE23
Postby that1mexguy » Sun Oct 30, 2005 9:46 am
When i changed my fuel filter all I did was remove the gas cap from the tank and that was it. http://www.solaraguy.org/viewtopic.php?t=17556 (1st pic)
that1mexguy
Postby JAYDEE23 » Sun Oct 30, 2005 10:04 am
thats it thanks
JAYDEE23
Postby StockSolara » Sun Oct 30, 2005 11:17 am
that1mexguy wrote:When i changed my fuel filter all I did was remove the gas cap from the tank and that was it. http://www.solaraguy.org/viewtopic.php?t=17556 (1st pic)
fa sho
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby noodlerooney » Mon Nov 21, 2005 10:03 am
If the car sits without running for about an hour, the fuel line pressure will be around zero. I don't think the gas cap has anything to do with fuel line pressure. Specifications require the fuel line pressure to be xxpsi xxminutes after shutting down engine (not full operating pressure). Over time, about an hour, all pressure is lost in fuel line system. If you wait, you will not get showered with gas. The fuel filter bolts are a b**ch tho....
15,001 miles, Garage Queen
noodlerooney
Postby Astro » Mon Nov 21, 2005 10:23 am
noodlerooney wrote:The fuel filter bolts are a b**ch tho....
Sooo true...
Postby saxophonoia » Mon Nov 21, 2005 2:27 pm
I always unplug the fuel pump under the back seat just to make sure I don't get too much gas when changing it but it's not that big of a deal.
"Humanity is like a teenager: old enough to cause real damage and too stupid to prevent it or do anything about it."
saxophonoia
Postby Solorange » Mon Nov 21, 2005 3:02 pm
How often does the fuel filter need to be replaced? Every 60k I think Ive read before?
Postby methyl mike » Tue Nov 22, 2005 2:41 pm
I tried to do it over the weekend and I couldnt get it off! Howd you guys do it???? I started stripping the damn thing.
methyl mike
Users browsing this forum: Google [Bot] and 34 guests
