SolaraGuy.com • View topic - 2 Things of concern?
Postby Nyyankees3511 » Sun Oct 30, 2005 6:09 pm
Im in need of a keyless entry remote and it seems that i can get one on ebay. But i see many styles including ones with trunk buttons. Im not sure if my trunk could be opend by that remote. Which remote do i need? I have a 2000 SLE if that helps. Thanks
Ive noticed my last fillup that i have gotten the worst gas mileage that i have ever had. I filled up using shell. Before that fillup i used prestone fuel treatment that supposedly cleans out everything. What could be the cause?
Nyyankees3511
Postby BradOwens » Sun Oct 30, 2005 6:29 pm
on ur first question...our 2000 solaras didnt have the remote that came with the trunk opening button. tht was available on the 02-03s i think? but remember u will need to reprogram the keyless entry to work with ur car. on ur second question i have no idea.
BradOwens
Postby Nyyankees3511 » Sun Oct 30, 2005 6:34 pm
Thanks. So i need the remote without the trunk button. How could i make sure i have keyless entry?
Nyyankees3511
Postby BradOwens » Sun Oct 30, 2005 6:42 pm
Nyyankees3511 wrote:Thanks. So i need the remote without the trunk button. How could i make sure i have keyless entry?
o so u didnt jus lose ur old one? well i would take it to the dealership and check with them to be safe. if ur car didnt come with a stock alarm then i would jus buy an aftermarket one
BradOwens
Postby Nyyankees3511 » Sun Oct 30, 2005 7:33 pm
No all i got was a key.
Nyyankees3511
Postby NeFaRiOuS_SLE » Sun Oct 30, 2005 7:50 pm
Yeah, you'd need a trunk that can be electronically released; the Solara has an internal trunk release controlled by a cable (which is ironic considering that my first car, a '91 Buick Century had an electronic release).
Postby Nyyankees3511 » Sun Oct 30, 2005 8:06 pm
Yeah thats what i figured. How could i make sure i have keyless entry.
Nyyankees3511
Postby indiglosolara » Mon Oct 31, 2005 10:02 am
Nyyankees3511 wrote:Yeah thats what i figured. How could i make sure i have keyless entry.
Bring your car to the dealer to see if they even had the keyless entry installed in your car before. If the previous buyer didn't buy the car with keyless entry i highly doubt you have it.
I would just go with a aftermarket alarm..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Astro » Mon Oct 31, 2005 10:06 am
Just go aftermarket, it'll probably be cheaper than trying to get you car setup for keyless. Plus, you'll have an alarm.
Postby GenerationOne » Mon Oct 31, 2005 10:13 am
yeah I've thought about making my trunk electronic and remove the key hole and cable, only way in would be with the remote button. I'm sure that would surprise thieves. :lol:
GenerationOne
Postby Jai_Jai_Binks » Mon Oct 31, 2005 10:22 am
You need a FCC ID Code for your car (if it came installed with either an alarm or keyless entry). I once came across a remove with my fcc id with a trunk popper, meaning, once reprogrammed it would have worked for the arm/disarm, but i would need to add a soiniod to make the trunk popper work..needless to say, i think i sold it to a member here.
Bottomline: isolate your fcc id code, once you have that figured out, seek our remotes from ebay w/ your fcc id and buy from there and ask the seller for programming instrucitions...ususally they print them out when they sell you the remote!
Postby StockSolara » Mon Oct 31, 2005 11:03 am
I don't know about others opinion on Shell but they don't last as long as 76 and Chevron
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby indiglosolara » Mon Oct 31, 2005 4:09 pm
I dont think the gas mileage problem is with which companies gas you use but how your driving habits are and or if you are driving city or hwy more.
I use shell gas and chevron and with both i get about 350 to 375 miles to the tank. 14 gallons per fill up. I drive allot of hwy so obviously i get more mileage due to that. I get a avg. of 26 miles per gallon.
But if i were to drive more city which i use to i would only get about 300 miles to the tank. So you can see the diff. I would ocassionally gun it and have some fun... If you have a lead foot you will obviously eat up more gas..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby StockSolara » Mon Oct 31, 2005 4:34 pm
indiglosolara wrote:I dont think the gas mileage problem is with which companies gas you use but how your driving habits are and or if you are driving city or hwy more.
No. . . I refuse to admit that. . . :x . . .hahahaha
2000 Lexus GS400
StockSolara
Postby Nyyankees3511 » Mon Oct 31, 2005 4:38 pm
I drove easy this fillup on purpose to see how much my car would make but i got crap. I used shell, ill try mobil this time.
Nyyankees3511
