SolaraGuy.com • View topic - central power lock wiring?
Postby hari-bhari » Sun Nov 13, 2005 5:10 pm
i have my aftermarket alarm that im trying to wire and im having some trouble with wiring the door unlockng. the wiring diagram for the unit states that one wire needs to connect to the 'main line', one to 'up', and one to 'down'. it says the 'control line' and 'motor line' will connect to the original built in controller so i dont have to tap those.
in the wiring diagram i have, i have wire specifications for power unlock, power lock, lock motor, and unlock motor. does anyone know which of these correspond to the items above?
hari-bhari
Postby pythonjosh » Mon Nov 14, 2005 1:01 am
Which alarm do you have? That is a weird installation description.
pythonjosh
