SolaraGuy.com • View topic - healthy rpm range
healthy rpm range
healthy rpm range
Postby Guest » Tue Jan 07, 2003 6:40 pm
i was wondering what would be the healthy rpm range for a 99 sle v6?
is 4k bad? i don't need to take it to 4 when on the residential roads but on like 45 mph roads it feels like im goin nowhere unless i go above 3000.
don't want to decrease the life of my solara.
thanks
Guest
Postby Jackass-Jeff » Tue Jan 07, 2003 7:14 pm
up to 4k is 'normal'
beyond that is just for fun (unless you're going up a super steep incline)
1GR-FE ftw!
Jackass-Jeff
Postby Yanks0114 » Tue Jan 07, 2003 7:42 pm
You probally wont get great gas mileage if you are constantly doing 4k rpm so i'd try and keep it a little lower
Re: healthy rpm range
Postby Flipside909 » Tue Jan 07, 2003 8:09 pm
Anonymous wrote:i was wondering what would be the healthy rpm range for a 99 sle v6?
thanks
3k and below is best.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby NASTY » Tue Jan 07, 2003 9:21 pm
decrease the life??
come on, redlining it every now and then won't hurt
'01 SLE V6
NASTY
Postby Guest » Wed Jan 08, 2003 4:19 pm
redlining every once in a while may not hurt, but if you want ur car to last to at least 100k miles going up to 4 or 5k rpms may not be the right choice.
Guest
Postby Yanks0114 » Wed Jan 08, 2003 5:56 pm
If you do plan to redline your car make sure that its warm and that you change your oil regularly
