SolaraGuy.com • View topic - shut off after start, help!!!!!!!!!!!!!!!!
Postby townboy2 » Thu Dec 01, 2005 7:04 pm
happend about hour ago... when i almost complete stop at the stop light then the car die.. after i restarted the car it started but die right after it... is like the gas won't go up or something... battery is good but some water on both front singal light and one just off too, could it be the cause of it??? lucky that has AAA tow it home with in half hour.
86 RX-7 crashed
94 MX-6 I4 donated it
93 MR2Turbo sold
00 Solara SLE
86 MR2 N/A FREE from a friend... DONATED too
2007 Nissan Altima Hybrid
townboy2
Postby Jon11582 » Thu Dec 01, 2005 7:28 pm
No that cant be it.
Its it cranking?
Maybe your alternator is going...or something else.
2000 Black Solara SE
Jon11582
Postby Nyyankees3511 » Thu Dec 01, 2005 8:05 pm
Its most likely the IAC-idle air control valve.
Nyyankees3511
Postby WTF?? » Thu Dec 01, 2005 8:11 pm
Nyyankees3511 wrote:Its most likely the IAC-idle air control valve.
maaaaaaan where are you coming up with these solution possibilties?? you always came up with a ton of questions lol now you got solutions!!
but hey I call the IAC valve too.... its basically this IF you have to constantly rev the gas in order to keep the engine running... cleaning the Throttle Body helps
Retired... its been fun Image
WTF??
Postby townboy2 » Fri Dec 02, 2005 5:45 am
i have clean 2 weeks ago, i think... it cranked and it started but die right after it... after i got back home from work and start it, it has start about 2 time for a minute and it die. i'll try to clean again, can it be the spark plug after i cleaned it???
86 RX-7 crashed
93 MR2Turbo sold
00 Solara SLE
townboy2
Postby Assyrian » Fri Dec 02, 2005 10:42 am
actually, I had a problem similar to that in my MX-6 and it was the alternator... but these guys know more about the solara than I do.
-Edgar
A noobie with an 02 SEV6 MTX
Assyrian
Postby Down2TheC » Fri Dec 02, 2005 10:51 am
Alternate to look at:
Fuel filter (Top of my list if it's old)
This one's a looooong shot but if when it dies, the entire electrical system goes dead for a moment and then she won't start for 15 min or so, then check for corroded injector leads. That took 6 months to find on a Pontiac once.
Down2TheC
Postby indiglosolara » Fri Dec 02, 2005 11:19 am
its the IAC-idle air control valve, This happened to a friend of mine not too long ago with this Solara.
its about a $250.00 fix..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Yanks0114 » Sun Dec 04, 2005 7:45 pm
Agreed with the IAC - happened to my brothers camry and that was the fix
Postby Nyyankees3511 » Sun Dec 04, 2005 8:51 pm
LOL wtf. Lets just say i learned a lot on this site. To make sure its not the alternator bring it to autozone and they will check your starting system, alternator, and battery for free. See if this works, under the throttle body where you can rev the car from inside the engine, look directly under that and youll see a black thing connected to the throttle body with a wiring harness connected to that, lightly tap it with like a screw driver or something and see if the car will start after that. You can even take it out by unscrewing the two screws and try and clean it. Good luck.
Nyyankees3511
Postby townboy2 » Mon Dec 05, 2005 4:08 am
the car it start but just die after it... u can't have a test on alternator unless the car stay on, i think.. i have in the shop hopfully will find out what happen today. thx all
86 RX-7 crashed
93 MR2Turbo sold
00 Solara SLE
townboy2
Postby octang1 » Tue Dec 06, 2005 12:42 pm
Let me know what you find is wrong! My 00 camry is doing the same thing I just haven't had the time to fix it.
2000 Solara SLE, Supercharged 6lb, CAI, Tokico/Eibach/Whiteline suspension
octang1
Postby townboy2 » Wed Dec 07, 2005 3:55 am
haven't heard anything from the shop yet... but pretty sure going to be IAC... not sure which part yet, either sensor or the thor. body
86 RX-7 crashed
93 MR2Turbo sold
00 Solara SLE
townboy2
Postby townboy2 » Fri Dec 09, 2005 12:23 pm
got a called today still haven't found the problem yet after changed the fule filter and sensor that next to the air box... i guess i'm in the market for car again
86 RX-7 crashed
93 MR2Turbo sold
00 Solara SLE
townboy2
Postby townboy2 » Tue Dec 20, 2005 8:50 pm
octang1 wrote:Let me know what you find is wrong! My 00 camry is doing the same thing I just haven't had the time to fix it.
have u found out what happen to your camry yet... the shop still can't slove my problem. 2 weeks with out my solara :evil:
86 RX-7 crashed
93 MR2Turbo sold
00 Solara SLE
townboy2
