SolaraGuy.com • View topic - car pulled a check engine light today
Postby BradOwens » Fri Dec 02, 2005 10:02 pm
yea so i was coming home from a getting a haircut and it just randomly popped up. so me and my dad took it to autozone to pull up the code. i dont remember the code exactly but it said i was running lean and needed a new o2 sensor. so tomorrow im getting a bosch o2 sensor to fix it. just thought id share.
BradOwens
Postby StockSolara » Fri Dec 02, 2005 11:08 pm
Did it mention which O2 sensor? cause I remember a member on here said he had a code like that and he just removed and it cleaned it off and it worked find. . . it was just kind of dirty
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby BradOwens » Sat Dec 03, 2005 8:04 am
StockSolara wrote:Did it mention which O2 sensor? cause I remember a member on here said he had a code like that and he just removed and it cleaned it off and it worked find. . . it was just kind of dirty
bank 1 i think he said? im pretty sure it was the main one. the sensor itself was near the headers
BradOwens
Postby RichD978 » Sat Dec 03, 2005 8:13 am
i got p420 for a while.. the 02 sensor in the exhaust pipe. I got the code repeatedly for i'd say twice a week for a good month and a half. after resetting it and resetting it, it just disappeared
RichD978
Postby Aaron » Sat Dec 03, 2005 8:18 am
Anybody know what PO440 code is. thats the one I get.
Aaron
Postby Paladin06Greg » Sat Dec 03, 2005 8:31 am
P0440
(DI–282)
Evaporative Emission Control
System Malfunction
Hose or tube cracked, holed, damaged or loose seal ((3) in
Fig. 1)
 Fuel tank cap incorrectly installed
 Fuel tank cap cracked or damaged
Vacuum hose cracked, holed, blocked, damaged or disconnected
((1) or (2) in Fig. 1)
 Fuel tank cracked, holed or damaged
 Charcoal canister cracked, holed or damaged
 Open or short in vapor pressure sensor circuit
Vapor pressure sensor
 Fuel tank over fill check valve cracked or damaged
ECM
Aaron wrote:Anybody know what PO440 code is. thats the one I get.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SC V6 » Sat Dec 03, 2005 9:23 am
check your hoses...
SC V6
Postby 1st Gen Sol » Sat Dec 03, 2005 9:40 am
^^^^ That person was me, but it was right after I installed the exhaust, disconnected the battery also for 10 minutes and let the ECU reset itself while I was cleaning the o2 sensor....... 8)
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby Aaron » Sat Dec 03, 2005 10:08 am
Paladin06Greg wrote:P0440
(DI–282)
System Malfunction
Fig. 1)
ECM
Thanks,
Aaron
