SolaraGuy.com • View topic - high beam problem
high beam problem
high beam problem
Postby sahuddleston » Tue Dec 06, 2005 7:48 pm
my DRL's work fine but when i turn on my high beams only one works? help!
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby Nyyankees3511 » Tue Dec 06, 2005 8:01 pm
Your bulb is a dual filament meaning there are two parts to the bulb the high beam and and low beam part. One of the filaments is blown and you need new bulbs.
Nyyankees3511
Postby WTF?? » Tue Dec 06, 2005 8:22 pm
Nyyankees3511 wrote:Your bulb is a dual filament meaning there are two parts to the bulb the high beam and and low beam part. One of the filaments is blown and you need new bulbs.
right on the money! :D
Retired... its been fun Image
WTF??
Postby Nyyankees3511 » Tue Dec 06, 2005 8:35 pm
HAHA im tryin.
Nyyankees3511
Postby sahuddleston » Tue Dec 06, 2005 10:08 pm
replaced bulb - same problem
sahuddleston
Postby SpeedSTARs » Tue Dec 06, 2005 10:56 pm
stupidrunner54 wrote:replaced bulb - same problem
Try cecking the relay box located in front of the battery (Gen1 application). There should be a separate mini fuse for high and low beam left or right side applications. I believe it's a 15amp fuse or 10amp. check those out. Hopefully this helps out. :wink:
SpeedSTARs
Postby NeFaRiOuS_SLE » Fri Dec 09, 2005 1:07 am
Yeah, what he said. Also keep in mind that the DRLs for the Gen1 runs off the low beam (which is kinda stupid considering that Toyota didn't think of how rare the high-beams are used in urban driving and how this shortens the life of the low beam filament)
Users browsing this forum: Google [Bot] and 34 guests
