SolaraGuy.com • View topic - new dash
new dash
new dash
Postby AzN_DrAgoN48 » Fri Jan 10, 2003 11:29 pm
i was thinking about replacing the green light on the dash with a white light
like the ones in the benzs and lexus. any ideas?
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Re: new dash
Postby Flipside909 » Fri Jan 10, 2003 11:32 pm
AzN_DrAgoN48 wrote:i was thinking about replacing the green light on the dash with a white light
You can change the bulbs (194 wedge btw), but you wont get the look of a real Electroluminescent display like what you see on most Lexus models. The Electroluminescent display is a vaccum display which is pitch black when off, and glows bright when electrically powered. This unit costs about $1000+ for just the whole speedo cluster alone.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Ferrari_1299 » Sat Jan 11, 2003 3:54 am
How do you get to the bulb?
1999 SE V6
Eibach Springs, Tokicko Struts, CF Hood, Custom Grill, Clear Corners, more to come...
http://www.cardomain.com/memberpage/275185
Ferrari_1299
Postby Flipside909 » Sat Jan 11, 2003 10:18 am
Ferrrari_1299 wrote:How do you get to the bulb?
Take off the two phillips screws at the top of the speedo bezel, remove the bezel, take off the 3 or 4 screws holding down the speedo cluster in the back. Next you just have to angle the speedo cluster to get it out of the hole. Make sure you unplug the wiring and you should be able to get access to the whole back. The bulbs are located behind the "twist on" covers. There should be about 4 to 5 bulbs. I forgot exactly, it's been a LONG time since I took my dash apart.
www.clublexus.com
Flipside909
Postby Ferrari_1299 » Sat Jan 11, 2003 1:21 pm
Thanks Flipside.
1999 SE V6
Ferrari_1299
Postby Ferrari_1299 » Sat Jan 11, 2003 2:43 pm
I just changed my dash lights. It was real easy, thanks to flipsides step by step instructions, thanks. I put blue bulbs in instead of the green ones, I like it a lot.
1999 SE V6
Ferrari_1299
Postby Flipside909 » Sat Jan 11, 2003 4:16 pm
Ferrrari_1299 wrote:I just changed my dash lights. It was real easy, thanks to flipsides step by step instructions, thanks. I put blue bulbs in instead of the green ones, I like it a lot.
Which bulb brand did you end up going with? You may also want to change the bulbs behind the HVAC controls. In order to access those bulbs, you pull off all 3 HVAC knobs (i'm assuming you have an SE model) take a philips...remove the screws...and now you should be able to access the panel. If I recall correctly, those are 194 as well. :)
www.clublexus.com
Flipside909
Postby Peter » Sat Jan 11, 2003 4:40 pm
i cant get the stupid cluster out....
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby Flipside909 » Sat Jan 11, 2003 4:54 pm
Peter wrote:i cant get the stupid cluster out....
You have to angle it just right...and it will slide out.
www.clublexus.com
Flipside909
Postby krook » Sat Jan 11, 2003 7:36 pm
peter,
pull the cluster as far as possible toward you (give or take it's about 2-4 inches of movement) then, when it can't go anymore, rotate the bottom part toward you while sliding it out.
krook
Postby NASTY » Sun Jan 12, 2003 9:21 am
post pictures! (or someone whos done it, thinking about it)
'01 SLE V6
NASTY
Postby Peter » Sun Jan 12, 2003 11:48 am
i made mine red. picture came out kinda bad, i'll take a better one tonight
Visit Black Sheep
Peter
Postby Peter » Sun Jan 12, 2003 11:51 am
flip, can i make my clock red too? and my climate control too?
Visit Black Sheep
Peter
Postby Yanks0114 » Sun Jan 12, 2003 12:51 pm
Peter wrote:flip, can i make my clock red too? and my climate control too?
The clock you won't be able to make red. If you have auto climate control than you can't but if you have manual control then you could.
Postby AzN_DrAgoN48 » Sun Jan 12, 2003 1:14 pm
where can you get bulbs and how much?
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
