SolaraGuy.com • View topic - SOMETHINGS UP W/ MY CAR...
Postby HwEaNnRgY » Sun Jan 12, 2003 4:56 pm
as some of u guys might know, i just got my solara on the 26th of last month.. anyways now when i stop at a light or stop at a stop sign, there is like a vibration or a shaking of some sort like a rumbling in the glove compartment when i gas it again(inside the glove compartment isn't where you open the latch, but way INSIDE the glove compartment). It doesn't have that sound when i back up or anything, but just when i gas it. its sounds as if two plastic things are touching against each other but not sure wat it is. The sound is definitly from the passenger side and im not dure wat it is but.. ITS VERY ANNOYING AND IM ALMOST LOSING MY MIND!!!
HELP ANYONE??
HwEaNnRgY
Postby ICrazyChrisI » Sun Jan 12, 2003 6:34 pm
I get that problem from time to time, and i have a 99 SLE. What I usually do is just hit it :D Probably soon I'll just find a place to put dynamat or something to reduce the rattling.
ICrazyChrisI
Postby Missay » Sun Jan 12, 2003 6:42 pm
that's weird..ahh, just jack the volume up on the radio, you'll never hear it. :)
do you have the factory stereo system in?? if you can rule out the speakers causing the rattling, i'd have it looked at, cause god knows what's going on under there cause the noise. hopefully it's something simple.
Melissa
Missay
SolaraGuy Ambassador
Postby HwEaNnRgY » Sun Jan 12, 2003 9:00 pm
yea im pretty sure that its not the stereo and everything in my car is stock (so far). So im really like tripping out. Its not even that loud but i just don't like it and i'll take it to the dealer tomorrow and see wat they can do for me. thanks missy
HwEaNnRgY
Postby krook » Sun Jan 12, 2003 11:34 pm
bro, i'm pretty sure i know what it is.
try and move your pass. seat up a little. did you recently move your pass. seat to let someone in the back? did you do it by lifting the lever on the side? what happens when you do that is the WHOLE seat comes loose and slides back. the seat can't sit all the way back; it'll give you that "clinking" noise. check your seat.
krook
Postby bassthrive » Mon Jan 13, 2003 12:10 am
if youre sure its coming from behind the glove compartment and not something inside of it, you can easily pull open the rectangular panel beneath it and feel around inside for something that may be loose. it may take some acrobatics - put the passenger seatback down all the way and lie on it upside down with your head in the footwell to get the best view.
it may also be your passenger seat like krooked said. in my car the lever for the passenger seatback rattles when i go over some bumps. i fixed it by turning up the stereo. these JBL's give some great sound. :D
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Re: SOMETHINGS UP W/ MY CAR...
Postby 4banger » Mon Jan 13, 2003 3:33 am
HwEaNnRgY wrote:anyways now when i stop at a light or stop at a stop sign
Does it have anything to do with the radiator fan kicking on?
Silver '99 Solara SE 4cyl.
4banger
Toyota Solara
Postby adam2562 » Mon Jan 13, 2003 9:27 am
no no, my car does this too its a 99 also all its is, is that the latch where the glovebox locks in isnt as tight as it used to be so it gives it freeplay, like when i start out giong(manual) if its a shaky start it'll do it.... its nothing big just find out where the contact part is and put some piece of rubber or as "ICrazyChrisI" said put a piece of dynamat.. hope this helps c ya .... P.S. i need to find time to do it to mine lol
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby HwEaNnRgY » Mon Jan 13, 2003 6:25 pm
Thanks guys,
actually there is this panel under the glove compartment, i had to take that off and it was really that which was banging against something. One of the latches were broken so i just took it back to my toyota dealer to get a new one. Thanks for all the help though :D
HwEaNnRgY
