SolaraGuy.com • View topic - Flickering lights?!?!?!?!?!
Postby Dutch Master » Wed Jan 04, 2006 7:25 am
LEt me start off by saying the wire connector that goes into the left headlight looks like the connection shorted out and maybe one of the wires is frayed. The light goes off and on sometimes, more so it stays off.
Now heres the question.
When Im idling or come to a stop, all the lights in the car seem to dim and or flicker. The dashboard lights flicker too. Is the bad connection to the light the reason for this to happen? Or is it a battery or Alt problem?
Any help appreciated!
*searched found nothing on the subject
Dutch Master
Postby bassthrive » Wed Jan 04, 2006 8:02 am
I had a similar problem. A new battery fixed everything.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Dutch Master » Wed Jan 04, 2006 9:36 am
You think a new battery??......I guess since its a 2000 the previous owner didnt change the battery...What is the stock battery they put in Solaras...Gen1??????
I'll try it.......its wierd its like the lights ar about to die or something....
DM Records
myspace.com/dutchmasterrecords
Dutch Master
Re: Flickering lights?!?!?!?!?!
Postby TheGreenDutch » Thu May 27, 2010 11:15 am
Man my car still does this. I haven't been able to figure it out in the 5 years i've owned it....:(
sorry to revive an old thread. Maybe someone has the same problem?
TheGreenDutch
Postby feniks » Thu May 27, 2010 1:27 pm
check your all grounds. if there is a screwy ground somewhere, it will do that.
'02 Solara SLE 1MZ-FE/A541E Coupe .: Denso : Akebono SP : HIR :. @ 125k
'00 Solara SE 5S-FE/A140E Coupe .: NGK : Hawk HPS : Philips Xtreme : RC : Magnefine :. @ 79k
feniks
Users browsing this forum: Google [Bot] and 27 guests
