SolaraGuy.com • View topic - parking brake
parking brake
parking brake
Postby AzN_DrAgoN48 » Tue Jan 14, 2003 3:47 pm
every once in a while i'd be driving and the parking brake light would turn on. and no matter what i do it won't turn off. sometimes i stop at a red light and pull the parking brake and sometimes it would go off. others i just run my car like reg and it would turn off. any ideas? is the sensor broke.... etc.... thnx
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Postby Guest » Tue Jan 14, 2003 3:54 pm
I had that same prob in my Integra. I had no idea what the problem was, so I had to take it to an electrical repair place. They fixed it in less than 2 hrs. I know it was probably something easy to fix, but like I said, I really didn't know what it was (still don't). Anyway, take it to a Toyota dealer, and I'm sure they'll be able to fix it easily.
Guest
Postby impactX » Tue Jan 14, 2003 4:01 pm
Easier than anything...
You are low on Brake fluid.
Either go back to dealer if your car is under warranty or add it yourself. (DOT 3)
impactX
Postby Missay » Tue Jan 14, 2003 10:20 pm
i'm pretty sure ImpactX is right...i actually posted this same problem a couple months ago.
my mechanic just added some brake fluid for me..and it hasn't come on since. :D
(athough..doesn't that sorta scare you or paranoid you driving around w/ a light on that shouldn't be there? i hate that)
Melissa
Missay
SolaraGuy Ambassador
Re: parking brake
Postby Flipside909 » Wed Jan 15, 2003 2:08 am
AzN_DrAgoN48 wrote:every once in a while i'd be driving and the parking brake light would turn on. and no matter what i do it won't turn off. sometimes i stop at a red light and pull the parking brake and sometimes it would go off. others i just run my car like reg and it would turn off. any ideas? is the sensor broke.... etc.... thnx
Low brake fluid. Use Dot 3 Brake fluid or better.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Kenn157 » Wed Jan 15, 2003 5:02 am
Yes its low brake fluid. In my case it was low because the brake pads were worn down from previous owner. When I took the test drive the light was on. The dealer (Chevy) told me he'll have it checked. He did and said nothing was wrong. Well, there was something wrong. When I need to use the brakes on the highway I did slow down but it felt like I wasnt. I brought the car to Toyota and they said the brakes were almost gone :(
Check the brake fluid but also have the pads checked. The fluid is down for a reason. Just make sure your braking isnt compromised.
Had a 99 Solara SE V6. Had a 06 Tacoma. Now I have a 2008 Camry SE V6
Kenn157
Postby NaptownSolara » Wed Jan 15, 2003 6:06 am
Mookie. This is a chronic problem with Toyotas (My camry and solara both did it). Let's make this question part of the tech faq. Thanks, man.
2001 Toyota Solara SLE V6 - Silver
Alpine/Kicker audio system
NaptownSolara
Postby DavPak » Wed Jan 15, 2003 6:14 am
Kenn157 wrote:Yes its low brake fluid. In my case it was low because the brake pads were worn down from previous owner. When I took the test drive the light was on. The dealer (Chevy) told me he'll have it checked. He did and said nothing was wrong. Well, there was something wrong. When I need to use the brakes on the highway I did slow down but it felt like I wasnt. I brought the car to Toyota and they said the brakes were almost gone :(
kenn is right, have the pads checked.
i see this every day at work........well put kenn!!
'02 Solara S/C'ed V6 5-spd
DavPak
