SolaraGuy.com • View topic - fuel injector?
fuel injector?
fuel injector?
Postby Missay » Tue Jan 14, 2003 10:08 pm
ok...i'm thinking bout this whole low gas mileage/super loud idling noise w/ my car. could it be the fuel injector?
would that cause the mileage to suck and for the car to sound like crap?
Melissa
Missay
SolaraGuy Ambassador
Re: fuel injector?
Postby Flipside909 » Wed Jan 15, 2003 2:09 am
Missay wrote:ok...i'm thinking bout this whole low gas mileage/super loud idling noise w/ my car. could it be the fuel injector?
That's a possibility. A bottle of injector cleaner wont solve it usually. You have to get it serviced by a tech.
Loud idling sounds like you need a tune up or perhaps sticky valves.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby ICUFG » Wed Jan 15, 2003 10:54 am
Sounds like someone might have an engine gelling problem, maybe.
ICUFG
Postby Missay » Wed Jan 15, 2003 10:56 am
eeeeee :o how much $$ am i looking at?? it's a 99 w/ 42k..i'm outta luck on warranty, huh??
Melissa
Missay
sludge
Postby DavPak » Wed Jan 15, 2003 11:07 am
ICUFG wrote:Sounds like someone might have an engine gelling problem, maybe.
symptoms: blueish/black smoke coming out the tailpipe
slight stuttering while driving. however, i've never heard of sludging causing poor gas mileage or a noise.
missay, do you have a v6 or an i4?
the problem seems to be more prevalent in v6's
if it is a "gelling" condition the warranty is unlimited mileage.
'02 Solara S/C'ed V6 5-spd
DavPak
Re: sludge
Postby Flipside909 » Wed Jan 15, 2003 11:40 am
She has an SLE V6.
www.clublexus.com
Flipside909
Re: sludge
Postby Missay » Wed Jan 15, 2003 12:20 pm
Flipside909 wrote:She has an SLE V6.
ahhh..u know me too well :wink:
so should i ask the mechanic to check the fuel injector? or what else could be the culprit here?
Melissa
Missay
Postby NASTY » Wed Jan 15, 2003 12:25 pm
if it sounds funny idling couldn't that have something to do with the timing belt?
'01 SLE V6
NASTY
Postby ICUFG » Wed Jan 15, 2003 12:26 pm
NASTY wrote:if it sounds funny idling couldn't that have something to do with the timing belt?
Timing belt has nothing to do with it.
ICUFG
Postby NASTY » Wed Jan 15, 2003 12:29 pm
ICUFG wrote:Timing belt has nothing to do with it.
well, i tried :(
'01 SLE V6
NASTY
Valves
Postby ScottV » Tue Jan 21, 2003 8:55 am
You might have leaky valves. My Solara (V6) started to surge at idle and I took it in and found that the valves were leaking. The compression in the front three were 55psi, 120psi and 180psi. 180psi is what it is supposed to be. I am now getting the heads machined and a 3-angle valve job. For me, this was probably caused because I had ran my car to lean (7psi supercharger pulley without adjusting mixtures).
Scott
ScottV
Postby Jackass-Jeff » Tue Jan 21, 2003 10:41 am
uh oh... i think my idle has been a little louder than usual... *_* i might as well go bug the dealer hehehe... we just bought a LE, and XLE v6 from them last weekend
1GR-FE ftw!
Jackass-Jeff
