SolaraGuy.com • View topic - Sqeaky steering wheel
Postby FLASH » Wed Jan 15, 2003 1:15 pm
I have a problem. When I turn my wheel and let it retract back, it sqeaks on the way back to its straight position. I thought it would be my power steering fluid, but I just had that filled/changed. I was thinkin maybe some WD-40? Or would that cause problems?
Thanx.
FLASH
Re: Sqeaky steering wheel
Postby Flipside909 » Wed Jan 15, 2003 1:47 pm
FLASH wrote:I have a problem. When I turn my wheel and let it retract back, it sqeaks on the way back to its straight position. I thought it would be my power steering fluid, but I just had that filled/changed. I was thinkin maybe some WD-40? Or would that cause problems?
Thanx.
The plastics and stuff behind the steering wheel contract and expand from cold and heat over time. A lubricant wont solve your problem.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby FLASH » Thu Jan 16, 2003 3:46 pm
Considering I live in NJ and it's gotten mad cold over the past 2 months, that's the reason then. Thanks, Flip
FLASH
