SolaraGuy.com • View topic - Source for quality water pump/timing belt and struts
Postby JAYDEE23 » Sat Jan 21, 2006 7:46 am
I am looking for a cheap source to get somequality parts to swap out my timing belt, water pump, and struts..hitting 80k soon and figure i mine as well have my machanic do this stuff now
anyone know some good online sources with good prices..and is factory replacement considered the best you can do..minus the suspension of course
i am loking to retain factory ride quality..drop 1" would hurt either is i retain a good ride
Edit by Yanks0114: Please don't use all caps in your title
JAYDEE23
Re: SOURCE FOR QUALITY WATER PUMP/TIMING BELT. STRUTS
Postby WTF?? » Sat Jan 21, 2006 11:29 am
JAYDEE23 wrote:is factory replacement considered the best you can do..minus the suspension of course
yes
Retired... its been fun Image
WTF??
Re: Source for quality water pump/timing belt and struts
Postby Yanks0114 » Sat Jan 21, 2006 11:38 am
Thats kind of a double edged sword.
As far as I know, you can't do a 1" drop. It's 1.25 or greater. Lowering springs won't ruin ride quality, but it's not recommended to lower your car on stock struts. The rule of thumb is you can expect 1 year or 10-15k miles before you blow out the struts.
Aftermarket struts, such as tokico blues, can handle a drop (up to 2-2.5") without any reduction in strut life, however, your ride quality will change. The car will handle much better, but you'll feel bumps more.
