SolaraGuy.com • View topic - idle control sensor or tps??????
Postby lilm » Mon Jan 23, 2006 8:46 am
well my idle problem has now gotten worse.......it started droping revs while i was driving.....starting to do it EVERYTIME i stop now ......and is getting to be a very annoying problem.......what do i do
i searched for both idle cotrol sensor/ics/tps/throttle position sensor and came up with nothing:(
lilm
Postby Jai_Jai_Binks » Mon Jan 23, 2006 8:50 am
from personal experience. Idle control sensor problem symptoms: The car revs up and down at stop lights and intersections (like its breathing)...when the problem gets worse, the car stops on its own (due to low low rpms). We had this problem on our ford contour.
Postby lilm » Mon Jan 23, 2006 8:58 am
i doesnt go up and down.....its more like......it drops 100(prolly less) for like 1/4 sec oddly in what seems like intervals of three at a time then its fine.......but it also did it while going down westimer for like 3 green lights doing 40ish.....thats what bothered me
lilm
Postby Strider327 » Mon Jan 23, 2006 11:03 am
Try doing simple things first to test if the sensors are the problem first. Clean the Throttle Body thouroughly and do a seafoam treatment to see if it helps. If not then start looking into the sensors. Does your car seem to heating up more than normally? Does the engine shake violently? It maybe either the idle speed control valve or the engine coolant temperature sensor.
Good Luck
Calvin
Strider327
Postby lilm » Mon Jan 23, 2006 11:58 am
did the throttle body less than......500 miles ago....engine temp is normal..... battery is normal,alternator is normal,
lilm
Postby bassthrive » Mon Jan 23, 2006 4:04 pm
Did you disconnect your MAF sensor for any reason while cleaning the TB and forget to hook it back up? (though this would make your engine stop all together, not just dip in rpm) Also check for any vac lines you left disconnected after your TB treatment.
I had a similar problem when my battery started going bad, revs would drop. Got a new one and all was well again.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby lilm » Mon Jan 23, 2006 10:29 pm
nothing seems to be disconnected....
alot of ppl tell me its idle control sensor..... but no one tells me how to fix it :evilbat:
so is this someting diy.....or am i going to put off my rsb and muffler again :evilbat: :evilbat: :evilbat:
lilm
Postby DatSRBoi » Mon Jan 23, 2006 10:31 pm
Whats your mods? FIlter dirty? Is your Vaccum bad?
Postby lilm » Tue Jan 24, 2006 11:56 am
filter is in good shape not a spot on it....vac. lines are all in doesnt seem to be a leak or anything........
going to change the pcv valve.....and clean.....practically everyting.....
any more ideas?
lilm
Postby lilm » Tue Jan 24, 2006 12:31 pm
ok i messed with it a little and cleaned a bunch of things.......doesnt seem to be doing it....ill prolly change some of the hoses and maybe seafoam..... and ill keep you guys posted
lilm
Postby bunthy » Tue Jan 24, 2006 12:40 pm
See this thread I started. Look for "FLETCH"'s response.
http://www.solaraguy.org/viewtopic.php?t=22550
I haven't checked the TPS yet, but I have the EXACT SAME problem that you do man. Its some scary crap when your accelerate then the car starts chuggin and dropping rpm. My car haven't done this in the past, even when I s/ced it. It only started to happen a few months ago...I got s/ced in oct. When I find out the problem, I'll let you know.
Let me know too if you found the remedy.
I've tried changing gas startion for a fill up too to see if that helps....its not as bad know but its still there.
bunthy
Postby Jai_Jai_Binks » Tue Jan 24, 2006 12:42 pm
I have no clue how to change the idle control sensor..hence i didn't want to contribute. If your still experience problems, talk to matt or shawn, heck they've swapped 3s motors before..so this should be a cakewalk for them. I'm pretty sure matt's number should be my prior PM's to you.
Postby lilm » Tue Jan 24, 2006 3:35 pm
its stopped
no idea why....or what i did
:drinking:
lilm
Postby bunthy » Tue Jan 24, 2006 4:12 pm
it might come back chief. I was tinkering around too to see if I could fix it. It would stop then come back, hell it just did a few hours ago. This sucks.
bunthy
Postby lilm » Wed Feb 01, 2006 10:02 am
UPDATE!!!!
it did it once about two days after and thats it hasnt done it since.......guess a hose must have been messed up :o
lilm
