SolaraGuy.com • View topic - Brake light
Brake light
Brake light
Postby solaraluv » Thu Jan 26, 2006 10:45 pm
Does anyone know why the brake light would go on and off while driving I checked the pads and the have plenty of meat on them.
Loved by few hated by many
solaraluv
Postby solaraN8 » Thu Jan 26, 2006 10:46 pm
check the level of the brake fluid
New Car, 2003 IS300 5mt
solaraN8
Postby solaraluv » Thu Jan 26, 2006 10:56 pm
I did and it seems fine
solaraluv
Postby SolaraGuy22 » Thu Jan 26, 2006 10:58 pm
My brake light has been on for a few days itself but it's been steadily on. I took it in for a maintenance and it's still on and the brake fluid is full. They said I may need a brake flush or something like that. Hope you get your issue resolved. Drive safe in the meantime 8)
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby solaraluv » Thu Jan 26, 2006 11:01 pm
one guy said it was the master cylnder but doubt that.
solaraluv
Postby SleeperSolara » Fri Jan 27, 2006 7:30 am
solaraluv wrote:one guy said it was the master cylnder but doubt that.
No it couldn't be the master cylinder.
It either brake fluid low or need new fluid change............
You will know when you master cylinder goes bad, when you have bleed the brake calipers 4 time at seperate times, and the fluid is normal, and when you have new pads, and when you press the brake pedal it feels mushy.
That how you can tell that your master cylinder is goin' bad like mine.
Been bad since i bought the car. :(
Still tryin' to fab a bracket for a Supra brake master cylinder..................
Brake lite
Postby jim@foreignaffairs » Fri Jan 27, 2006 9:51 am
The brake light goes on due to either a low fluid level or the emergency (parking) brake handle being pulled up. A faulty brake handle switch, or the switch not being held open by the brake handle being slightly out of alignment or engaged may be a cause. There is no sensor that tells the system to light the light when the fluid is in need of changing. So while you may or may not need a fluid change, that does not have anything to do with the light being on.
jim@foreignaffairs
Postby BigPhizzle » Sat Jan 28, 2006 3:02 am
From my understanding, isnt the Master cylinder for the clutch? or is there a master cylinder for each - the brake and the clutch?
- Big Phizzle -
BigPhizzle
Postby NeFaRiOuS_SLE » Wed Feb 01, 2006 10:40 am
Not necessarily just for the clutch, but if I remember correctly (I'm not a mechanic, just read the some manual a long time ago), they are usually seperate but still use brake fluid. Someone correct me, please?
