SolaraGuy.com • View topic - Engine knocking
Engine knocking
Engine knocking
Postby solaraluv » Wed Feb 01, 2006 5:29 pm
I was just wondering if anyone has had a slight knocking in the engine for about a second during take off? It really only happens when I gun it from a stand still.
Loved by few hated by many
solaraluv
Postby adam2562 » Wed Feb 01, 2006 6:08 pm
i'm, assuming is a 4cyl.. try 2 tanks of 93 octane and see if it runs better? if not the could just be ur valves tapping.. (more sound like this on the V6 models) or then the worst yea it could be a rod knocking
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby onefiend » Wed Feb 01, 2006 6:16 pm
try some STP Fuel Injection cleaner and STP throttle body cleaner...you might just have dirty injectors
2007 Camry SE V6
onefiend
Postby solaraluv » Wed Feb 01, 2006 9:38 pm
Its a V6 and all I use is 93 or 91 octane gas, so if its a rod does that mean a engine rebuild?
solaraluv
Postby DatSRBoi » Wed Feb 01, 2006 9:42 pm
Might be a bad sensor
Postby solaraluv » Wed Feb 01, 2006 9:52 pm
so is this a sign of a bad sensor? because its only happens on thoese quick take offs when you floor it.
solaraluv
Postby DatSRBoi » Wed Feb 01, 2006 10:00 pm
solaraluv wrote:so is this a sign of a bad sensor? because its only happens on thoese quick take offs when you floor it.
I had that issue onces and they replaced my MAF sensor and it went away. Yours might be the same or a different sensor. Because usually if the throttle is dirty, it sholdnt cause that huge of a lag. Now you shuold open up and see if theres built up on the valves of the throllte positioner to make sure thers no built up there..if there isnt then it might be sensor.
Postby solaraluv » Wed Feb 01, 2006 10:05 pm
is the MAF sensor the same as knock sensors or are they different? Are parts expensive.
solaraluv
Postby DatSRBoi » Wed Feb 01, 2006 10:33 pm
solaraluv wrote:is the MAF sensor the same as knock sensors or are they different? Are parts expensive.
Comparing it to other cars, yes its kind of expensive. KNock sensors arnt MAF sensors. I think oem maf sensors are like 66 bucks...But Id througly check your car first to see what It really is causeing the issue.
Postby Turbosolara » Wed Feb 01, 2006 11:29 pm
5sfe is normal if you have one.
Postby Fratsgotasolara » Mon Feb 06, 2006 9:42 am
how many miles are on your car, how old are your spark plugs, have you had a dealer look at your car, what air filter do you have, how dirty is it and what other maintenance has been done or needs done?
"You may not know me, But your girlfriend does!" -Delta Chi OSU
Fratsgotasolara
Postby solaraluv » Mon Feb 06, 2006 9:42 pm
Im at 81k miles right now the plugs have been changed last spring 05' and im using the stock air filter now and its fairly new.
solaraluv
