SolaraGuy.com • View topic - Headlight bulb brightness not the same
Postby WhiteSLEV6 » Fri Feb 03, 2006 11:11 am
I installed new bulbs on my front headlights and one side seems to be brighter than the other side when i drive towards a mirror to see my light bulb reflection. Any suggestions on how to fix this?
http://www.pbase.com/pearlwhiteslev6
TRD Supercharger, Injen Intake
Eibach springs next!
WhiteSLEV6
Postby bunthy » Fri Feb 03, 2006 11:43 am
dirty headlamps? are both bulbs new? both fitted properly, i.e. one is not loose? bad bulb.
bunthy
Postby WhiteSLEV6 » Fri Feb 03, 2006 11:53 am
yes, they are new.. Just bought GE Nighthawks and installed it but one side is definitely brighter than the other side.. Both fit perfectly, Highbeams and lowbeams work but you can notice the brightness difference from the 2 bulbs if you stand like 15-20 feet across from the front. Could it be because of a dirty headlamp?
WhiteSLEV6
Postby SolaraGuy22 » Fri Feb 03, 2006 11:57 am
Are they Silverstars?
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby WhiteSLEV6 » Fri Feb 03, 2006 12:04 pm
No i used to have Silverstars and it did the same thing but you couldnt really notice the brightness difference like the new GE Nightawks.. I should switch back to Silverstars but they only last me like 5 months until they die out :-? Wanted to test new company's.. Hmm maybe I should try PIAA. The brightness difference is just unbearable right now with these Nighthawks.
WhiteSLEV6
Postby Nyyankees3511 » Fri Feb 03, 2006 2:50 pm
It could be your harness. If it happened with silverstars too then, it has to be three things eitiher the harness, one headlamp is aimed to far down and it makes it look like its dimmer, and dirty headlamps. To check if both lights are leveled drive up and turn your lights on against a wall, and check.
Nyyankees3511
Postby noodlerooney » Fri Feb 03, 2006 9:14 pm
I vote for headlight aiming is out of adjustment.
15,001 miles, Garage Queen
noodlerooney
Postby rossman945 » Sun Feb 05, 2006 8:06 pm
reaim your headlights, i had the same problem
rossman945
Postby sahuddleston » Sun Feb 05, 2006 8:48 pm
i agree - happened to me....
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby redkysolarase » Mon Feb 06, 2006 6:32 am
I've the same problem but I bought some cheapo lights to do me until I either got some more silverstars or something else. You can tell a really big difference in mine though cuz the drivers side looks like it's on bright just about. Up against a wall my passenger side is nice and flat just about but my drivers side is all over the place. Is that out of adjustment or what? And if so I really really hate to ask but how do I adjust my headlights?
redkysolarase
Postby rossman945 » Mon Feb 06, 2006 7:05 pm
There is a little bolt on the backside of the headlight casing, you cant miss it. Just find a wrench that fits it and turn it either way till the headlights are perfectly level.
rossman945
Postby Fratsgotasolara » Tue Feb 07, 2006 7:04 pm
park about 20 feet from a wall squarely and on low beam you should have both beams about 3-4 feet apart centered in relation to the car and they should be about 1-3 feet from the ground on high 3-5 feet
"You may not know me, But your girlfriend does!" -Delta Chi OSU
Fratsgotasolara
Postby WTF?? » Tue Feb 07, 2006 8:08 pm
rossman945 wrote:There is a little bolt on the backside of the headlight casing, you cant miss it. Just find a wrench that fits it and turn it either way till the headlights are perfectly level.
Retired... its been fun Image
WTF??
Postby redkysolarase » Tue Feb 07, 2006 8:17 pm
Ahh God bless you man that'll make a world of difference. Now if this stupid weather would just get warmer... stupid snow. :(
redkysolarase
Postby M_ABILLONES » Thu Feb 16, 2006 9:04 am
If I'm not mistaken, here in the U.S. the passenger side headlights are brighter than the driver's side. If not brighter then definitely aimed higher.
1. U.S. driver side is on the left. Meaning when you have an incoming traffic the other driver is facing the left headlamp. According to DOT, left side headlamps are supposed to be aimed slightly lower than the right to reduce glare and prevent "blinding" incoming traffic.
Dunno if that's really true but in simple terms it does make sense. I wonder which bored scientists came up with these solutions. What will we do without them..
Maybe we should call the Mythbusters
M_ABILLONES
