SolaraGuy.com • View topic - ???Question???
???Question???
???Question???
Postby solaraluv » Mon Feb 06, 2006 10:00 pm
What is a MAF sesnor? what does it do?
Loved by few hated by many
solaraluv
Postby solaraN8 » Mon Feb 06, 2006 10:15 pm
the MAF is the mass air flow sensor, and it converts the amount of air drawn into the engine into a voltage signal..the ecm needs to know the intake air volume to calculate the engine load..which is needed to know how much fuel to inject and when to ignite the cylinder..
Nate
someone correct me if im wrong??
New Car, 2003 IS300 5mt
solaraN8
Postby solaraluv » Mon Feb 06, 2006 11:01 pm
wow! you know stuff, thanks man. so how would I know if it stops working or if its not working properly?
solaraluv
Postby dominoSLEV6 » Tue Feb 07, 2006 12:58 am
Your engine might skip or backfire from running rich or it may be running a little lean which is very dangerous... your car may seem to be more or less liek it's lagging if the fuel mixture gets too rich. Many different symptoms and I'm not TOO well versed with MAFs, but if it is malfunctioning enough to produce any of these symptoms it should have already set off a CEL, no CEL and I don't think you have much to worry about, that is if you were worrying.
-chris
dominoSLEV6
Postby SleeperSolara » Tue Feb 07, 2006 9:03 am
dominoSLEV6 wrote:Your engine might skip or backfire from running rich or it may be running a little lean which is very dangerous... your car may seem to be more or less liek it's lagging if the fuel mixture gets too rich. Many different symptoms and I'm not TOO well versed with MAFs, but if it is malfunctioning enough to produce any of these symptoms it should have already set off a CEL, no CEL and I don't think you have much to worry about, that is if you were worrying.
-chris
Wow you on the sopt man.
Props. :D
