SolaraGuy.com • View topic - Wierd problem
Wierd problem
Wierd problem
Postby pvu » Sat Feb 11, 2006 9:41 pm
This has happened to me many times. I start my car up and it seems the engine started, but it wont stay on. The rpm barely reaches 1k and the engine slowly shut off while making a nasty sound and the check engine light would come on. Then I restart the engine and everything's fine and no more cel. This doesn't happen everytime but once in awhile. My car is a 99 and has over 100k. What could the problem be?
pvu
Postby sydemoid » Sat Feb 11, 2006 10:24 pm
clogged fuel filter?
clogged catalytic converter?
fouling spark plugs?
ignition ok?
just a few questions I would ask myself in your situation...
sydemoid
Postby Yanks0114 » Sat Feb 11, 2006 10:51 pm
Sounds like a bad Idle Air Controller (IAC). If you rev the engine will it stay on?
Postby DatSRBoi » Sat Feb 11, 2006 11:13 pm
Yanks0114 wrote:Sounds like a bad Idle Air Controller (IAC). If you rev the engine will it stay on?
Wheres the IAC located? And how much does it cost?
Postby pvu » Sat Feb 11, 2006 11:28 pm
Never tried reving the engine. I will try next time and see what's up.
pvu
Postby hskrsolara » Sun Feb 12, 2006 8:12 am
fuel pump?
hskrsolara
Postby lilm » Sun Feb 12, 2006 1:58 pm
HAD The same EXACT problem......if you try revving the engince does it seem like only a couple cylinders fired.....its a freaky problem....mine would sometimnes take like 5-10 try to get the damn thing to start........but when i cleaned the throttle body it seemed to stop.....it hasnt done it in at least 3 months
lilm
Postby newroc » Wed Mar 01, 2006 8:02 pm
did you guys find out what the problem is? throttle body needs cleaning?
It happened to me for the first time today, cold idle at 200 w/ rough trembling for like 5-10 seconds and dies. After a few times turning restarting and going nowhere, i revved the engine at 2000 and kept my foot there for a couple minutes, then everyting goes back to normal, as if nothing happened.
I got an I4 w/ new batteries, had oil changed and added K&N drop in last week, so maybe the ecu is adjusting to the changed air flow and the new oil?
newroc
Postby Mole » Wed Mar 01, 2006 8:52 pm
^ nope... car stays on to adjust settings.
sounds like what yanks said.
Postby DatSRBoi » Wed Mar 01, 2006 10:20 pm
Mines doesnt do it as much anymore... But it does drop the RPM TOOOO low when I turn the A/C on.. Could that be a sign? Because I cant up the RPM throttle line anymore. I already max it out.
Postby Strider327 » Thu Mar 02, 2006 10:14 am
clean the throttle body and seafoam it. It should clear up this problem.
Strider327
