SolaraGuy.com • View topic - back driver side strut raddling...
Postby AznDragonV » Mon Feb 13, 2006 2:00 am
my driver side back strut raddles...do u think its loose? its been like this fo a while....do u think it will do any harm?
AznDragonV
Postby dominoSLEV6 » Mon Feb 13, 2006 6:57 am
I don't know if it's loose, my guess would be probably yes. As for harm, it depends on the severity of the parts malfunction. I don't have much info to work with here, but I've never heard of this as a major Solara malfunction. I'd guess it's nothing big, but it's also limited info I'm workign with here. MY best advice is to just check it out yourself, if it's rubbing you should be able to tell, if it's comething else, just check bolt tightness etc. and see if it goes away. If you can't remedy it yourself a local tire/suspension place can tell you what's up. Then you can have them fix it or you can take another stab at it yourself.
-chris
dominoSLEV6
Postby Fratsgotasolara » Mon Feb 13, 2006 7:05 am
loose as in unbolted or loose like the strutmount went bad? if its coming unbolted it could mess up the mounting place on the car, or break off the studs on the top of the mount, but if its just the mount it will just be annoying and cause the tires to wear awkwardly and be very annoying when driving on bumpy surfaces, its pretty common to have a bad mount on a camry or solara
"You may not know me, But your girlfriend does!" -Delta Chi OSU
Fratsgotasolara
Postby Yanks0114 » Mon Feb 13, 2006 9:14 am
I'd be willing to bet its not lose.
It is probally the strut mount
Postby AznDragonV » Mon Feb 13, 2006 1:49 pm
yea i tried to see if the bolts were loose, but the bolt on the back of the seat got stripped so i couldnt take out the seats ....so that means i couldnt take out anything else..so it was hard to see wat was goin on..do u know how to fix a sripped bolt? so i can get at the strut?
AznDragonV
Postby RichD978 » Mon Feb 13, 2006 1:53 pm
isn't there something to get stripped bolts out ?
RichD978
Postby Duffman » Tue Feb 14, 2006 4:37 am
I had a similar issue with my '02 Solara. I ended up just taking it to Toyota; the strut had gone bad, so they replaced it.
As for stripped bolts... drilling them? Perhaps vice grips?
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
