SolaraGuy.com • View topic - oil brand
oil brand
oil brand
Postby hari-bhari » Mon Feb 13, 2006 10:50 am
i know everyone on this forum recommends mobil 1 synthetic, but since I don't drive too much since im at school, it seems like a waste to get my oil changed every 3-4 months especially when its expensive mobil 1. and i park in a deck, and atlanta weather is pretty mild, so if im getting my oil changed every three months, probably around 1500-2000 miles, is it ok to go with generic brands?
hari-bhari
Postby Jai_Jai_Binks » Mon Feb 13, 2006 10:56 am
Yes, as long as you keep a check on your oil and ensure you use a new 'reputed' filter everytime you should be good. (pls don't use fram).
Postby SleeperSolara » Mon Feb 13, 2006 3:07 pm
I'm usin' Catrol oil right now wit a Bosch filter.
Don't like the OEM Toyota filter, cause the size of the filter is to small for the tools i have at home.
Yes don't use FRAM oil filter they suck donkey. :x
About to switch to Castrol semi-syntheic.
Postby Yanks0114 » Tue Feb 14, 2006 3:05 pm
I'm in the same situation.
I use mobil 1 and KN oil filters. I change the oil after about 6 months or 3000 miles. I think its a much better alternative then using generic oil, and it gives me the peace of mind that I'm using synthetic
Postby jhenty » Tue Feb 14, 2006 3:16 pm
normally I use mobil 1, but last week I switched to royal purple.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby Solorange » Tue Feb 14, 2006 9:14 pm
I use mobil 1, an alternative for you is to keep using the mobil 1 but dont change it every three months. Just change it at 3000k. Also on the bottle it says the oil is good for 7500k for semi synthetic (what I use). Change it every 4500k or something to be on the safe side. Im too picky so I do it every 3000k. Ive never paid attention to the 3 month thing.
Postby SleeperSolara » Wed Feb 15, 2006 7:56 am
Yeah i always change mine at 2k miles.
Cause by then it he oil is black and nasty lookin'.
Postby hari-bhari » Wed Feb 15, 2006 8:34 am
well see hte probablem is for me, it took me 6 months to hit 3k miles. is it a good idea to leave it in there for that long?
hari-bhari
Postby Jai_Jai_Binks » Wed Feb 15, 2006 9:23 am
if your leaving oil in for 6 months and barely hitting 3K miles, then i'm make sure its syn oil (nothing wrong with dino, but syn give me a peace of mind)
Postby onefiend » Wed Feb 15, 2006 9:45 am
Synthetic oil isnt that much more expensive, especially if you purchase it yourself.
Like what the others said "peace of mind".
2007 Camry SE V6
onefiend
Postby Yanks0114 » Wed Feb 15, 2006 9:22 pm
SleeperSolara wrote:Yeah i always change mine at 2k miles.
The black color is because of all the detergents in the oil. It's normal
Postby leepoffaith » Wed Feb 22, 2006 9:06 am
I have a question in regards to synthetic vs. regular oil. If you buy a used car that has used regular oil all its life, is it ok to change to synthetic? I heard that it messes with the seals. Just curious.
leepoffaith
Postby Jai_Jai_Binks » Wed Feb 22, 2006 12:34 pm
leepoffaith wrote:I have a question in regards to synthetic vs. regular oil. If you buy a used car that has used regular oil all its life, is it ok to change to synthetic? I heard that it messes with the seals. Just curious.
^^ SEARCH, if the seals were cracked they were cracked to begin with, and all the sludge/stuff was 'sealing' it. When you may switch, you may experience leakages that were already there to begin with. It doesn't 'lead' to new ones. But nothign wrong with dino...(i use dino on one car and synthetic on my other).
