SolaraGuy.com • View topic - Powersteering problems.
Postby TRDmonkey » Mon Feb 13, 2006 12:32 pm
I've seen to have problems with my power steering, it went out 2 nights ago and I took it home and let it sit and the next morning it still didint work at first, then after like 5 min it came back. Then after like 15 min later it went out again. I was going to get new tires and an alignment (but i couldnt get the alignment) and when i got there it still wasnt working. After the tires it was still not working and after about another 5 min it was working again. It has been working until this morning but I didnt drive it much and it went out again as i was driving home and i was moving the steering wheel back and forth and i felt it it come back. So what could be the cause of this problem?
Cliff notes: Powersteering goes on and off. What is the problem?
99 SLE V6 Solara
92 SC300 5 Speed Turbo
90 300ZX Twin Turbo (Sold)
87 N/A MKIII (Sold)
TRDmonkey
Postby TheTamago » Mon Feb 13, 2006 1:13 pm
*cough* Time for a new pump n flush? simple as that??
TheTamago
Postby RichD978 » Mon Feb 13, 2006 1:19 pm
maybe you have to get a new power steering pump like I do.. I'm 99 SE V6 with 90K miles... you?
RichD978
Postby Jai_Jai_Binks » Mon Feb 13, 2006 1:19 pm
(might be a stupid comment) have you checked your fluid? i say this, cus i've freaked out..only to realise that was the problem...
Postby SleeperSolara » Mon Feb 13, 2006 3:04 pm
Yeah check you fluid reservior for the power steerin' [hopefully you know where it at]
If it still full check the lines if they're bad or what not.
If they're good, then the power steerin' pump is the problem.
Postby TRDmonkey » Mon Feb 13, 2006 5:01 pm
Yeah, I've checked the fluid and it is fine. I kinda figured it was the pump but I just wanted to see your opinions.
99 SLE V6 Solara
87 N/A MKIII (Sold)
TRDmonkey
